hi
i have a small problem whit my rmx console..
when i go to the rmx control panel and configure the input like this "mic on line 1-2"
(usb streaming 1-2 + mic)
the mic always works, even when the mic and the source 1 button is in off possition :-/
is this normal?
thanx for your help!!
hmm never herd of that one! im sure someone can assist you with that here!
the hardware mix option in the rmx control panel allow either of the input 1-2 (line in or microphone) to be automatically sent to output 1-2 of the rmx, along with the main mix. for the microphone, the main difference with the talk over mode is that a level attenuation is available.
for most cases, the default setting should be selected since most dj software can handle input management.
ok
so its normal i can not turn of the mic whit dose settings?
correct.
for these cases where, use the talk over (mic on/off).
Hmm never herd of that one! im sure someone can assist you with that here!
The Hardware Mix option in the Rmx Control panel allow either of the input 1-2 (Line In or Microphone) to be automatically sent to Output 1-2 of the Rmx, along with the main mix. For the microphone, the main difference with the Talk Over mode is that a level attenuation is available.
For most cases, the default setting should be selected since most DJ software can handle input management.
ok
Correct.
For these cases where, use the Talk Over (Mic On/Off).
