1
Posts
2
Users
Reactions
Views
17/01/2019 1:25 pm
hi guys,
wonder if anyone has ever had this problem, i have the hercules rmx and it works perfectly most of the time but sometimes when i load a song the pitch wheel has a fit and which ever way i turn it the song goes backwards, i loose my abilty to pitch up. the only way i can get round it is to load another song which has the potential to mess up my live set
edit* forgot to mention im using virtual dj
any ideas?
17/01/2019 4:51 pm
Hello Lopephish,
I did not meet this issue but I remember getting a similar issue with some old build of VirtualDJ, when pressing on the Fast Forward keys, I could get the fast forward keeping on while I had released the key.
1) What is your version of VirtualDJ ? Are you on Mac or PC ?
2) To know whether it comes from the D controller or from the DJ, can you try mixing on the Rmx with Djuced ( https://www.djuced.com/downloaddjuced/ )?
- If you get also this issue in Djuced, it probably comes from the controller,
- if you cannot get this issue in Djuced, it probably comes from the software.
