hello
i have a strange issue with my air...ok i ll try to explain it as better as i can...
i get a distored flanger effect on my sound here and then...
i have noticed that i get this when i submit a form on web or when i transmitting data...
also when i open a program or start a proccess in a program and cpu is load 100%...
more details
i dont have this problem with other soundcard..
i have this issue even when im using air as soundcard...
i have wifi internet connection
i have disabled all features in my air control panel like proximity sensor,jog wheels,effects..etc
when this flanger distored effect starts it doesnt sound for same duration every time...it depends...
i havent use my air in other pc to see if it happens there too...
i have 1,5gb ram,1gb graphics,intel pentium 4 3ghz...
can it be my specs?or anyone has the same issue?
in the beginning i though that is cause of wifi and the sensor but i get it even with disabled sensor or with disabled wifi...
any help please,thanks
