subwoofer with mk4
subwoofer with mk4
i have looked all over and i cant find an answer. is it possible to have a powered subwoofer with the mk4?
I don't understand your question: you can connect any powered speaker with a stereo input, including a powered subwoofer on the Mk4.
- If you have a 2.1 speaker kit (1 sub-woofer + 2 satellites): connect the sub-woofer to the output 1-2 (RCA) and the 2 satellites to the 2 outputs of the sub-woofer
- If you have a stereo speaker kit + an independent separate sub-woofer: connect the stereo speaker kit to 1 pair of stereo output 1-2 (for example stereo jack 1/8") or and the sub-woofer to the other output 1-2 (for example the RCA output).
As of right now I only have one powered speaker, a behringer euro. I ask because I know the mk4 doesnt have a sub output. I'm not crazy knowledgeable about wiring. I run a RCA cable from output 1, I know this only gives me mono but money is tight...any way I can still hook up a sub without having twO?
Ooo ok I think I'm starting to understand. I don't have the sub yet, I wanted to make sure it would work with my powered speakers first. Any way you could dumb that down alittle? Haha
