sync button problem...
sync button problem instinct....
hello, ihave this strange problem with the sync button on the instinct controller.
when i press it during a set,the music slows down!!!
i do have the latest drivers and software from djuced. i hope someone has an answer....
patrick.
This probably happen because the two songs you are trying to sync have a too large difference in BPM (beat per minute).
For example, if a song is playing at 140 BPM and you try to sync it with a song at 100 BPM, it will understandably have to slow down in order to play at the same pace as the slower song. If you want another way to look at it, imagine a jogger having to slow down to the speed as someone walking.
To get a better understanding, I would suggest this video (and everything else by ellaskins) :
Hi and thanks alot for the quick reply....
It's just that it is not trying to slow down to reach the 100 bpm as you say....
It's slowing down to let's say 20 bpm?  I mean REALLY slow.... Sync is getting lower than the bpm of the playing track....
Not like one track is trying to get close to the bpm of the other track.
Sorry for my crappy english btw.... Hope you understand....
Greetingz from am old school vinyl DJ...
Were these tracks properly analyzed previously?
What is the respective BPM of the tracks?
Have you modified the Pitch range from the default 6% ?
