the rmx sound card
the rmx sound card
is there anyway of turning the soundcard off?
what it is is that im using a hercules rmx through vdj 7 but iv just brought  a ni audio 8 soundcard but would prefer to use this instead of the the rmx one but still use the rmx as a mixer, is there anyway round this as when i hook it all up i cant get any sound
Just choose the NI Audio 8 ASIO in the audio config
yeah iv tryed that but if i choose the audio 8 asio nothing else on the hercules seems to work
I haven't used VirtualDJ for a couple of years now, as I use MixVibes Cross.
Could you do a screen shot of the audio config tab in VirtualDJ.
Hello dnbnick,
Once you have set the Audio 8 DJ as sound card in VirtualDJ Pro> Config > Sound Setup tab, you must go to the Mappers tab, and set Hercules DJConsole RMX as mapped device, and you will control VirtualDJ on the Rmx while playing on the Audio 8 DJ.
