the usb port on my rmx seems awfully loose. theres been no problems with connectivity since i bought it, but it seems like an issue (a catastrophic issue) waiting to happen. i was wondering what the experience has been regarding this with other rmx users. thanx gang! -z-
hello stevez,
i have not heard of such an issue, but
- do you mean the female usb plug (the part of the rmx attached to the printed circuit inside the rmx) moves
- or do you mean the male usb plug (the part attached to the usb cable) moves inside a fixed female usb plug?
the male usb plug (the part attached to the usb cable) moves inside a fixed female usb plug.
thanx for responding. -z-
hello stevez,
a usb cable can move a little bit up & down in a usb port but without impact on the connection between the pc and the usb device (you can compare with another usb device to see if it is normal or not).
--> did you loose sometimes the rmx due to this or not?
--> have you tried with different usb cables?
Hello Stevez,
I have not heard of such an issue, but
- do you mean the female USB plug (the part of the Rmx attached to the printed circuit inside the Rmx) moves
- or do you mean the male USB plug (the part attached to the USB cable) moves inside a fixed female USB plug?
The male USB plug (the part attached to the USB cable) moves inside a fixed female USB plug.
Thanx for responding. -Z-
Hello SteveZ,
A usb cable can move a little bit up & down in a usb port but without impact on the connection between the PC and the usb device (you can compare with another usb device to see if it is normal or not).
--> Did you loose sometimes the Rmx due to this or not?
--> Have you tried with different usb cables?
