timecode signal pro...
timecode signal problem
hey, i am having a problem when using time code vinyl. i am using a macbook, and this happens with both my rmx and trim. when i first turn on the vinyl i have  a great signal usually at 100. but after a while, i lose the signal. it drops to somewhere between 3 and 30%.  and at that point the vinyl is usless as the signal is to bad and i have horrible control. can anyone tell me what may be causing this? ive got new vinyl and everything but it keeps doing this.
hello,
please precise
- which vinyl disc you use (virtualdj or serato)
- how much time it takes to lose the signal (as 5 minutes, 1 hour, 4 hours, 8 hours ?)
- if you have disabled the wifi & bluetooth on your macbook.
you should really complete your profile here with your complete computer profile (mac os version, dj console drivers, virtualdj version: we always need the same technical information for any technical problem)
sorry, i updated profile.   wifi and bluetooth are off. and it the time frame varies, sometimes it takes an hour sometimes 3 hours.
apple macbook 3, 1
mac os x version 10.6.7
2 ghz intel core 2 duo
4 gb 667 mhz ddr2 sdram
bus speed 800 mhz
vdj version 7.0.2 pro - (mac b347)
hercules driver package v2.47
hello epic,
can you check once virtualdj has stopped operating properly, in your rmx or deejay trim control panel, that the input mode is unchanged (phono or line, depending on your setting)?
is your turntable operating in phono or in line level?
my turntables are operation in phono mode
hello epic,
i suppose you are chandrez on virtualdj forum.
can you confirm that
- except the vinyl control the audio playback it still ok when the vinyl control comes down?
- if you restart virtualdj everything is smooth again?
as another user has met the same issue with vdj 7.02 while it was ok with vdj 6, can you test if you have the same issue:
- with virtualdj 6 pro
- with virtualdj 7.0.3 pro?
Please precise
- which vinyl disc you use (VirtualDJ or Serato)
- if you have disabled the wifi & bluetooth on your MacBook.
You should really complete your profile here with your complete computer profile (Mac OS version, DJ Console drivers, VirtualDJ version: we always need the same technical information for any technical problem)
Sorry, I updated Profile.   WIfi and Bluetooth are off. and it the time frame varies, sometimes it takes an hour sometimes 3 hours.
Apple Macbook 3, 1
Mac Os X Version 10.6.7
2 Ghz Intel Core 2 Duo
4 GB 667 MHz DDR2 SDRAM
Bus Speed 800 MHz
VDJ Version 7.0.2 Pro - (Mac b347)
Hercules Driver package v2.47
Hello Epic,
Can you check once VirtualDJ has stopped operating properly, in your Rmx or DeeJay TRIM control panel, that the input mode is unchanged (Phono or Line, depending on your setting)?
Is your turntable operating in phono or in line level?
My turntables are operation in Phono mode
Hello Epic,
I suppose you are Chandrez on VirtualDJ forum.
Can you confirm that
- except the vinyl control the audio playback it still OK when the vinyl control comes down?
- if you restart VirtualDJ everything is smooth again?
As another user has met the same issue with VDJ 7.02 while it was OK with VDJ 6, can you test if you have the same issue:
- with VirtualDJ 6 Pro
- with VirtualDJ 7.0.3 Pro?
Hey yes I'm chandrez in the virtual dj forum. I dont have the previous versions to test. I will try to see if they are stored somewhere on my laptop
