so i have the rmx working almost perfect, havent had any recognition problems anymore, all the buttons and knobs work for the most part except...
i cant get any of the kill buttons working or the medium knob working... i believe those are the only buttons that do not work, anyone have any ideas ?
i looked through the settings in midi set up and they all seem to be mapped out to the correct keys, but they dont work.... im not sure what else to do, anyone else have this problem ? im using traktor 3.
test your rmx as a midi controller using the procedure described in the following document:
http://ts.hercules.com/faqs/eng/her_eng_00353.pdf/blockquote >
that wont work, its only for windows... i have a mac computer, thanks
Test your Rmx as a MIDI controller using the procedure described in the following document:
That wont work, its only for windows... i have a mac computer, thanks
