traktor and traktor...
traktor and traktor 2 momentarily freeze w hercules rmx
im experiencing an odd issue with my hercules rmx.
when im in traktor 1 or 2 the software tends to freeze for a little bit, 5 or so seconds, every 30 minutes approximately. i am not certain if this is a traktor or hercules problem but im trying to get help from both sides.
after the freeze, the software resumes as though nothing happened. if i am recording, the silence is not recorded. i can still move my mouse and navigate to other applications, so its not as though all of windows 7 freezes.
im using asio mode with the following settings: 44.1 khz sample rate, 16-bit sample size, 10 ms buffer size.
should i try lowering the settings to some other values? if so, which ones? is there anything else that may be contributing to this problem? seeing as how the issue occurs in both versions of traktor, it is sort of hard to pin the problem on native instruments software.
Hi vladk,
This is something you could defenitely check out:
Greetz
TheCause
