26/08/2016 6:17 pm
i have traktor scratch pro and a rmx2 and if i have traktor open and connect the rmx2 it wont connect to the audio. it only seems to connect when the rmx2 is switched on 1st and then i connect to traktor. is there any way around this??
several of us use the same laptop to have a mix and its annoying when you change over and have to shut traktor down just to connect
