traktor pro 2 x her...
traktor pro 2 x hercules dj console rmx 1 (mac) - no headphone audio
sooooo, ive seen a lot of topics regarding this subject, but none of them was able to solve my problem yet. when i connect my controller to my macbook pro (running yosemite) i get no audio trough my headphones at all. no cue, no nothing. i do get audio trough my monitor which is attached to input 1-2.
i did all the steps as told in the .tsi file that i downloaded from the hercules website (see images).
what do i do wrong?
thx in advance.
And the problem seems to be present on both headphone output of the Rmx ( the top and front one)?
Is this a unit you've used successfully with headphones on another computer before ?
You've verified the headphone mix and Headphone level controls within Tracktor ?
I played on this computer before, yes. Headphone sockets work, If change my output routing the other way around (so output monitor front R/L output master, back R/L) then I do have audio trough my headphones.
Volume I need to check, but I can't imagine it's turned down.
Good to know there doens't seem to be a mechanical problem with the connectors.
So what changed on your computer since the day when everything was working ?
