traktor pro mapping
traktor pro mapping
hey peeps,
i have a dj control instinct and am having problems getting the correct tsi mapping file for traktor pro 2
i am using xp and currently have traktor 2.0.1. i cannot find the tsi file anywhere. the only tsi file on the website is for 2.6 and above which i cannot use on xp.
what is the latest version of traktor which i can use on xp and has a easily findable tsi file
thanks
The DJControl Instinct came out at a time when Traktor 2.5.0 was around, so it is quite unlikely that you'll find mapping for an older version of Traktor.
Unless you can upgrade (version 2.5.0 is the last version supporting Windows XP), you might need to create your how mapping for the controller.
http://www.native-instruments.com/en/support/knowledge-base/show/672/how-to-set-up-a-generic-midi-controller-in-traktor/
http://www.native-instruments.com/en/support/knowledge-base/show/698/how-to-use-the-controller-manager-in-traktor/
