09/12/2009 7:37 pm
hey!
so, yeah... it seems that when running those under snow leopard, on my imac, the jog wheels work a little bit then they stop working...
i also noticed that the lag between the controller is a lot smaller on traktor than on virtual dj... though, the wheels work fine on virtual dj...
=p
so, any ideas? im such a noob on all this, and any help will be much appreciated. =d.
vic
09/12/2009 7:43 pm
dang... just figured it out...lol
you need to put the menu/mouse as empty. =d
then they work... i guess its made like that just so you wont bump on the wheels when youre not up for it.
=d
09/12/2009 7:43 pm
Dang... Just figured it out...LOL
You need to put the menu/mouse as EMPTY. =D
Then they work... I guess it's made like that just so you won't bump on the wheels when you're not up for it.
=D
