trouble with my rmx...
trouble with my rmx on mac with traktor pro
when i start traktor pro with me dj console rmx connected, i dont get any sound out!! just in my headphones.
ive tried settting the audio device to "dj console rmx aggregate (4in, 4out) ... but when i try to set the outputs, i dont get the options for aggregate out 1-4 ... i just get front left, front right, back left and back right ...
can anyone please tell me how to fix this issue? i have a gig coming up, and it freaks me out a bit here ...
my system:
hercules dj console rmx
macbook pro
os x: snow leopard 10.6.2
rmx drivers: 1.7.7
traktor version: pro 1.1.1.001
please help me .. πŸ™‚
take a look at the document included with the midi mapping available on the hecules support site:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=215&cid=5
it explains how to configure the soundcard in traktor.
i would also recommend updating to the latest version of traktor (v1.2.3), which as been optimized to  work in snow leopard.
hope you found a solution since 2 months.
the 4 output are those of your hercules rmx and you should connect a sound system to it.
i think the problem is that you want sound output on your mac.
in this case, you have to :
1. go in "audio & midi configuration" application (in applications -> utilities)
2. find the "hercules dj console rmx aggrgate" device
3. check "integrated output" for this device to add 2 output
4. relaunch traktor
5. choose "hercules dj console rmx aggrgate" as audio device
6. choose output 3 & 4 for output monitor
7. choose output 5 & 6 for output master
Take a look at the document included with the MIDI mapping available on the Hecules support site:
It explains how to configure the soundcard in Traktor.
I would also recommend updating to the latest version of Traktor (v1.2.3), which as been optimized to  work in Snow Leopard.
Hope you found a solution since 2 months.
The 4 output are those of your Hercules RMX and you should connect a sound system to it.
I think the problem is that you want sound output on your Mac.
In this case, you have to :
1. Go in "Audio & MIDI Configuration" Application (In Applications -> Utilities)
2. Find the "Hercules DJ Console RMX Aggrgate" Device
3. Check "Integrated output" for this device to add 2 output
4. Relaunch Traktor
5. Choose "Hercules DJ Console RMX Aggrgate" as Audio device
6. Choose output 3 & 4 for Output Monitor
7. Choose output 5 & 6 for Output Master
