ubuntu 16.04 with h...
ubuntu 16.04 with hercules dj console rmx flashing lights
hello there, can someone help me? when i connect my dj console rmx with my computer using the usb cable the mixer its starting flashing blue lights but nothing is happening. it is just flashing forever. i have downloaded some drivers, but later deleted them as people have told me that i dont need drivers if i want to use the mixer with mixxx 2.0. can someone help me? thanks
test Hello,
I am not a Linux user so I have asked a colleague to do the test:DJ Console Rmx is well detected in Ubuntu 16.04 on his PC.
If the blue lights flash endlessly, it means the controller boot does not work on your computer, so I suggest you connect the Rmx to the PC via a USB hub which comes with a power adapter.
On Ubuntu 16.04 DJ Console Rmx is seen as a multichannel sound card:
And when you ask a test of the USB, the computer sees it as HID (here, the test on a Dell Optiplex)
test@test-OptiPlex-7010:~$ dmesg |tail
[  414.810355] usb 1-1.4: USB disconnect, device number 5
[  422.433011] usb 1-1.4: new full-speed USB device number 6 using ehci-pci
[  422.592190] usb 1-1.4: New USB device found, idVendor=06f8, idProduct=b101
[  422.592195] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  422.592198] usb 1-1.4: Product: Hercules DJ Console RMX
[  422.592200] usb 1-1.4: Manufacturer: Hercules
[  424.961221] input: Hercules Hercules DJ Console RMX as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.5/0003:06F8:B101.0005/input/input16
[  424.961538] hid-generic 0003:06F8:B101.0005: input,hidraw2: USB HID v1.10 Device [Hercules Hercules DJ Console RMX] on usb-0000:00:1a.0-1.4/input5
[  424.965955] input: Hercules Hercules DJ Console RMX as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.6/0003:06F8:B101.0006/input/input17
[  424.966233] hid-generic 0003:06F8:B101.0006: input,hidraw3: USB HID v1.10 Mouse [Hercules Hercules DJ Console RMX] on usb-0000:00:1a.0-1.4/input6
i think u r right and my usb power output of the laptop is not enoght πŸ™ this is what i get from usb power supply when i run usb-devices | grep 'Product=\|MxPwr'
S: Product=xHCI Host Controller
C: #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=0mA
S: Product=2.4G Receiver
C: #Ifs= 3 Cfg#= 1 Atr=a0 MxPwr=100mA
C: #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
S: Product=USB2.0 VGA UVC WebCam
C: #Ifs= 2 Cfg#= 1 Atr=80 MxPwr=500mA
so what do you suggest i can do in this case?
I suggest you place a USB hub powered by a power adapter between your computer and the DJ Console Rmx unit.
