using deckadance wi...
using deckadance with a mk 4 controller
hi there am trying to get deckadance linked up to my mk 4 controller. so far have tryed linking through the setup section but nothing happens, do you have to link all knobs and sliders individually???? andy
the dj console mk4 is natively supported by deckadance with the latest version 1.80:
http://deckadance.image-line.com/documents/history.html
if you are using an earlier verison, you would indeed need to manually configure the controller. it would be much easier to simply update your version.
The DJ Console MK4 is natively supported by Deckadance with the latest version 1.80:
If you are using an earlier verison, you would indeed need to manually configure the controller. It would be much easier to simply update your version.
i have recently bought a mk4 to work with deckadance club edition 1.93
i can control the software with the console but the headphone doesn't work. the Pre-listening doesn't work.
i tried with virtual dj ( the one included) and everything works fine, but not with deckadance.
any suggestion?
Hi i have deckadence 1.93, it should be newer than 1.80 but i still have the problem.
in setup in the list of the supported console i can find the mk4 but i cannot use the headphone pre listening.
do you know how to solve the problem?
thank you
Hello Giulio,
Maybe you are in WDM in Windows, and it prevents you from accessing to channel 3 and 4 ?
1) in DJ Console Mk4 control panel, switch the audio mode to ASIO
2) check Mk4 is on MIDI channel 1
3) in Deckadance central area, click on Setup button and select DJ Console Mk4 as remote control device
4) run Deckadance and click on button Settings (top left)
5) in Settings panel, select as Audio Device Hercules DJ Console Mk4 ASIO.
