vdj and loop in and...
vdj and loop in and out points
on some music files i cant seem to end a loop at the exact spot where i selected.  i am using an rmx with vdj pro and i can select the in (starting) point of the loop precisely, but when i select the out (stopping) point of the loop it creates a totally different out point that then doesnt work with the beat.  is there something i am not doing correctly or need to fix?  thanks.
You should check the Smart loop status: the smart loop is activated/disabled in clicking on the lock symbol close to the Loop in/out buttons on VirtualDJ Pro skin.
Thank you.  That solved it.  Also, the songs I had problems with needed manual recalibration of the BPM.  Once I recalibrated them manually the looping worked with Smart Loop as well as without.  Thanks again for answering this so quickly.
