bought the rmx, installed the drivers, but my pc doesnt recognise my rmx...
in my device manager, i see the rmx, but there is a yellow ! sign in the icon.
i have the recent drivers of the rmx, my os is vista...
any ideas?
Did you try the installation using the latest drivers (2010.HDJS.2) or the ones provided on your CD ?
Have you tried installing the Rmx on another USB port or another cable?
I tried everything, but it wont help...
Matthias
What is the exact error message in Device Manager ?
Are certains components of the Rmx installed at all ?
Everything is installed, but the 'bulk' and the 'Asio' devices are with a yellow '!'
I can't even open the control panel!
Windows has detected a problem with your device, it is not working properly.
Try this:
- Press the MIC On/Off button, and while holding it, connect the USB cable to the Rmx.
Normally, the bulk driver should be redetected ( and installed) and the firmware updater should appear ( simply follow the instructions).
If that doesn't work, I guess You'll have to go all the way:
http://ts.hercules.com/faqs/eng/her_eng_00384.pdf
The firmwire updater doesnt recognise the console, it never does after 20 times...
Do you have any possibility of trying it on another computer to see if you get similar results ?
On my other pc does it work, but on my laptop it has been working, but when i tried updating for working with the VDJ 6 Serie, it doesn't works anymore...
So the Device isn't broken, the cable is doing well, it just my laptop....
This is good news. At least we know that it's not a hardware problem wit the console.
What I would suggest for your Vista laptop:
1) Uninstall the drivers as you normally would.
2) Run a software like CCleaner ( http://www.piriform.com/ccleaner) to clean and fix registry entry that could be causing problems on the system.
3) Install the latest Windows updates ( if you haven't already)
4) reboot the computer
5) Disable all antivirus and protection softwares you may have running, make sure you have administrator privileges and try the installation of the drivers again.
I just removed all HDJ or Hercules dj stuff out of my register... I hope it works!
The bulkdrivers are installed well, but there is still no contact between my laptop and the RMX...
In device manager, I see an error with Unknown devices, and than the Hercules DJ Console RMX with an erroricon...
by the way, now I couldt open the "C:\Program Files\Hercules\Audio\DJ Console Series\firmware\HDJSeriesUpdater.exe" –manual file... "Error MSG File" or something...
And if you disconnect the Rmx, do you still have problematic devices in Device Manager ?
If this is the case, then that could be part of the problem.
If everything is fine, then let's try something else.
Simply connect the Rmx to another USB port. What happens ?
If some of the devices still show Yellow !, try a manual installation:
- Right -click on the device and select Update Driver Software
- then select Browse my computer...
- Next, Let me pick the driver..., then click on Have Disk
- Browse to the driver installation folder:
C:/Program Files/Hercules/Audio/DJ Console Series/drivers
Click OK to complete the browsing process and go back to the installation window, then proceed withthe manual installation.
The sound device is working, but the rest still doesnt work...
when i disconnect the rmx, i didn't have an error...
when i plug the usb in another port, i still has an error.
when i was going to the folder, it says: your unknow device couln't be installed by windows (but in dutch)...
Nothing helps
Driver error is: the system is unable to find the specified file...
Is that the error you get for all components that have a yellow ! in Device Manager ?
I'm starting to think there might be some problems with your Vista installation...
You have Service Pack 2 installed for Vista I hope ?
The controller has worked for a year, so there isnt anything with my OS
Ah! From your initial post, it sounded like you had just bought the Rmx and were trying to install it for the first time...This makes a big difference then.
What happened between the moment when it was working and now ?
I tried to update my drivers for VDJ 6.0, so I deleted all Hercules drivers, and now it won't work on the newest drivers, and on the old drivers...
That reminds me of something...
You are on Vista 32 or 64 bit ?
Its on my laptop, so 32 bit
Can you check the properties for the following file:
- Wdf01000.sys
- WdfLdr.sys
You will find these files in
C:\WINDOWS\system32\drivers\
In the DETAILS tab, what is the version for each of the files?
If these files are hidden ( they normally should be) , follow these instructions:
http://windows.microsoft.com/en-CA/windows-vista/Show-hidden-files
Phatso,
The version is 1.7.6001.0 for the both files
Good. This is exactly what I thought.
I've just sent you a friend request (go to MYSPACE in the top menu) to accept it. You will then be able to send me a private message with your email adress. I will send you some files with some instructions you will need to follow.
I have accept you at myspace.
Email sent.
