vdj settings for be...
vdj settings for best performance?
and one more question. i know i saw this somewhere, but i searched all over and cant find it again. what is the best configuration to use with the rmx with vdj. i mean for the performance tab. i think the default is configured to be used with  simple soundcard on the laptop. i dont know if i am wrong i shouldnt touch that or if there is a better setting than the default to get the best out of the rmx. i dont know what anything on that tab means, so please help.
thank you.
if you have virtualdj pro 5.2.1, then you could follow this
http://www.virtualdj.com/wiki/hercules%20rmx%20setup.html
i did it for the virtualdj wiki, the last 2 pics show the settings i run my rmx on, im not saying there the best but i havent had any touble from my rmx so far
hope that helps a bit. laughing
thanks jimmy
If you have VirtualDJ Pro 5.2.1, then you could follow this
http://www.virtualdj.com/wiki/Hercules%20RMX%20Setup.html
I did it for the VirtualDJ wiki, the last 2 pics show the setting's I run my RMX on, I'm not saying there the best but I haven't had any touble from my RMX so far
Hope that helps a bit. Laughing
thanks jimmy
