since a month i have a rmx 2 now. it is exceeding my expecation.
but there is one little problem...
i am experimenting in mixing a track by jumping back and forth from/to all the cue-point i have set (from cue-point 2 to cue-point 1 to cue-point 3, and so on, sometimes in a rather quick tempo). but the pressure, i have to put in the command causes me to be out of time and creates a sense of delay. i came to the conclusion that that using the velocity pads for playing from a set cue-point not the best option for me (i would rather have a standard switch for samples and cue-point mapping).
i do need to practive more. but i would prefer an other sulution to my problem.
is there a way to change the velocity settings for the cue/sample mode sepperatly?
can i map function to buttons i usually dont use (for instance mic/pm/off or source 1)?
are there other solutions besides practicing?
i would be gratefull
