virtual dj 7 + cont...
virtual dj 7 + control air
firstly i apologize for my english, im using google translate to talk to you.
im trying to use it hercules dj control air along with the virtual dj pro 7.0.5 full, already caught in the mapping site of hercules, and some things work and others do not, i use the controls on the notebook and my speakers are usb that are connected to the notebook, both the parent how the speakers are connected to the notebook, oh my doubt is how i can have sound output on the speakers and the headphone return are running at the same time? the problem is that im not able to have the audio headphone.
how to configure my vdj this situation, sound box + usb controller two, and take back the sound that this headphone connected to the controller.
thanks and i look forward answers (and please let me repospondam using english as simple as possible so that i correctly translate google translate).
smk
You Need to use the "ADVANCED CONFIG" of VDJ to do this.
Add some audio routing by clicking the + button.
Then choose :
MASTER => YOUR_USB_SPEAKER_SOUNDCARD => 1/2 (i think)
HEADPHONES => DJ Control Air ASIO => 3/4
Attention, this Configuration is NOT recommended, you risk to get some audio lags, and latency beetween the two outputs.
Hercules DJ Control Air / Virtual DJ Sound Setup
Hi, well I bought Hercules DJ Control Air and I finally could configurate audio setup on Virtual DJ 7 without any problems.
Here I left a image how you got to configurate Sound setup on Virtual DJ 7.
It's works perfect, i didn't have a problem yet.
hi i have one question if you please help me
Usualy I should be able to hear the music from both decks playing in my headphones at the same time At present I can only hear the deck that is cued so I am unable to try to mix as it is just jumping from one deck to the other.
