virtual dj - hercul...
virtual dj - hercules air cant use it
i need help asap!
i use virutal dj pro for my hercules air cause i find its better then the program that came with it
and i dont know how to sync it up with virtual dj to use it
i know it might have something do it with confiquring it manually
and i know i am so close to fixing it and using it
but i need someone to guide me!
thanks
Did you get the configuration files from the Support site ?
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=287&cid=10
you need to download the mapping code in order to use it in virtual dj..
after downloading just copy the mapping folder for dj control air , then paste it on virtual dj folder mapper
