hi!
just upgraded to virtual dj pro 7 after buying a hercules rmx and using the standard v-dj software for abit.
the v-dj le software that comes with the rmx with the present buttons allow the loop in button to reloop the loop at the point its pressed during the loop. e.g. shortening the loop to where its pressed to where you last pressed loop out.
however ive been setting up the buttons on the rmx in virtual dj pro and the loop in button doesnt seem to overide the previous loop in to the new point when pressed. it simply restarts the loop at the orignial point it was pressed to loop in.
is there a special button command for a loop in that when pressed resets the loop in at whatever point during the loop you want? so you can shorted the loop yourself rather than looping out ans quickly looping in/out again.
any help appreciated!
thanks.
Your answer lies in understanding the secrets of the VDJScript:
http://www.virtualdj.com/wiki/VDJscript.html
Thanks again phatso..but I've been trying all night and reading through the guides/looking up on how to mapp script and still no luck π
Do you have any idea how what sort of basis of the script it would be i.e variation parametre etc?
I've even tried to copy the mapping from the LE version but that didn't want to work lol
