Hardware Remapping for DjControl Inpulse 200 MK2 on DJUCED
1 Reactions
1
Hi, i'm currently loving my new controller, but i would love to change the mapping. I would love to have a Mid knob, maybe using the SHIFT + Gain or SHIFT + High and also would want to put Echo FX effect on a knob maybe using once again SHIFT + HIGH or SHIFT + LOW. Also, since i don't use much Samples i would love to put Loop Rolls on at least one of the SHIFT + STEMS (Sampler) pad or if it isn't possible, even on the SHIFT + HOTCUE (fx) 4th Pad since it isn't very useful. Would love to bind the assistant to "Next FX" to use on the Main Filter knob too. If anyone has a way of doing, or better, teaching me how to do this changes in DJUCED, i would very appreciate it. Thanks.
did u find a way?
