DJControl Inpulse 200 series
Posts
1
Users
Reactions
5
Views
22/01/2024 5:31 pm
I wasn’t aware there was an Mk2 version of the Inpulse 200, so I didn’t understand why the mapping file provided here ( https://support.hercules.com/en/product/djcontrolinpulse200-en/) wasn’t showing up in the djay app when I imported it.
I modified the USB ID in the file to match the ID found in my Mac’s System Report (116961584, had to combine and convert the Vendor and Product ID to decimal), then it imported and matched my device successfully.
Since the Mk2 doesn’t have a mid-EQ dial, I removed the duplicate mapping then re-added the high-EQ.
Save the below code as DJControl Inpulse 200 Mk2.djayMidiMapping
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"><plist version="1.0"><dict><key>USBID</key><integer>116961584</integer><key>controls</key><array><dict><key>keyPath</key><string>turntable1.playPause</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>7</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.playPause</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>7</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.cuePositionOrJumpConsideringPlayState1</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>6</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.cuePositionOrJumpConsideringPlayState1</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>6</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.bpmSync</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>5</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.bpmSync</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>5</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.loopIn</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>9</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.loopOutAndReloopOrUnloop</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>10</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.loopIn</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>9</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.loopOutAndReloopOrUnloop</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>10</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.speed</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>8</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>turntable2.speed</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>8</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>turntable1.scratchingMode</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>8</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>controlType</key><string>rotary</string><key>keyPath</key><string>turntable1.scratchingMove</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>10</integer><key>midiMessageType</key><integer>3</integer><key>rotaryAcceleration</key><integer>100</integer><key>rotarySensitivity</key><real>30</real></dict><dict><key>keyPath</key><string>turntable2.scratchingMode</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>8</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>controlType</key><string>rotary</string><key>keyPath</key><string>turntable2.scratchingMove</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>10</integer><key>midiMessageType</key><integer>3</integer><key>rotaryAcceleration</key><integer>100</integer><key>rotarySensitivity</key><real>30</real></dict><dict><key>keyPath</key><string>turntable1.jogPitchBendModeToggle</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>3</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict><key>flipped</key><true/></dict></dict><dict><key>keyPath</key><string>turntable2.jogPitchBendModeToggle</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>3</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict><key>flipped</key><true/></dict></dict><dict><key>controlType</key><string>rotary</string><key>keyPath</key><string>turntable1.pitchBendMove</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>9</integer><key>midiMessageType</key><integer>3</integer><key>rotaryAcceleration</key><integer>100</integer><key>rotarySensitivity</key><real>30</real></dict><dict><key>controlType</key><string>rotary</string><key>keyPath</key><string>turntable2.pitchBendMove</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>9</integer><key>midiMessageType</key><integer>3</integer><key>rotaryAcceleration</key><integer>100</integer><key>rotarySensitivity</key><real>30</real></dict><dict><key>controlType</key><string>rotary</string><key>keyPath</key><string>turntable1.jogSeekMove</string><key>midiChannel</key><integer>4</integer><key>midiData</key><integer>9</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>turntable2.jogSeekMove</string><key>midiChannel</key><integer>5</integer><key>midiData</key><integer>9</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>turntable1.fx1Enabled</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>0</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.fx1ParameterValue</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>6</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>turntable1.fx1WetDryValue</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>7</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>turntable2.fx2Enabled</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>0</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.fx2ParameterValue</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>6</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>turntable2.fx2WetDryValue</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>7</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>mixer.crossfade</string><key>midiChannel</key><integer>0</integer><key>midiData</key><integer>0</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>mixer.lineVolume1</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>0</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>mixer.lineVolume2</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>0</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>turntable1.filter</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>1</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>turntable2.filter</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>1</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>turntable1.lowEQ</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>2</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>turntable1.highEQ</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>4</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>turntable1.gain</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>5</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>turntable2.gain</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>5</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>turntable2.highEQ</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>4</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>turntable2.lowEQ</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>2</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>mixer.monitorActive1</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>12</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>mixer.monitorActive2</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>12</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>musicLibrary.toggleLibrarySource</string><key>midiChannel</key><integer>0</integer><key>midiData</key><integer>0</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>controlType</key><string>rotary</string><key>flipped</key><true/><key>keyPath</key><string>musicLibrary.libraryRotary</string><key>midiChannel</key><integer>0</integer><key>midiData</key><integer>1</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>musicLibrary.load1</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>13</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>musicLibrary.load2</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>13</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>turntable1.autoLoopDurationDouble</string><key>midiChannel</key><integer>4</integer><key>midiData</key><integer>10</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>turntable2.autoLoopDurationHalf</string><key>midiChannel</key><integer>5</integer><key>midiData</key><integer>9</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>turntable2.autoLoopDurationDouble</string><key>midiChannel</key><integer>5</integer><key>midiData</key><integer>10</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>turntable1.autoLoopDurationHalf</string><key>midiChannel</key><integer>4</integer><key>midiData</key><integer>9</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>turntable1.cueOrJumpIfAlreadySet1</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>0</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.cueOrJumpIfAlreadySet2</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>1</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.cueOrJumpIfAlreadySet3</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>2</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.cueOrJumpIfAlreadySet4</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>3</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.cueOrJumpIfAlreadySet5</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>4</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.cueOrJumpIfAlreadySet6</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>5</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.cueOrJumpIfAlreadySet7</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>6</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.cueOrJumpIfAlreadySet8</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>7</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.bounceLoop00625BeatInterval</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>16</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.bounceLoop0125BeatInterval</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>17</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.bounceLoop025BeatInterval</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>18</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.bounceLoop05BeatInterval</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>19</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.bounceLoop1BeatInterval</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>20</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.bounceLoop2BeatInterval</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>21</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.bounceLoop4BeatInterval</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>22</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.bounceLoop8BeatInterval</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>23</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>buttonMode</key><string>toggle</string><key>keyPath</key><string>application.toggleShowEffects</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>17</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict><key>flipped</key><true/></dict></dict><dict><key>keyPath</key><string>turntable1.slicer8Slice1</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>32</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.slicer8Slice2</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>33</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.slicer8Slice3</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>34</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.slicer8Slice4</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>35</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.slicer8Slice5</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>36</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.slicer8Slice6</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>37</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.slicer8Slice7</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>38</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.slicer8Slice8</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>39</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>sampler.turntable1.player1.playingConsideringHoldSetting</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>48</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>sampler.turntable1.player2.playingConsideringHoldSetting</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>49</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>sampler.turntable1.player3.playingConsideringHoldSetting</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>50</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>sampler.turntable1.player4.playingConsideringHoldSetting</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>51</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>sampler.turntable1.player5.playingConsideringHoldSetting</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>52</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>sampler.turntable1.player6.playingConsideringHoldSetting</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>53</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>sampler.turntable2.player1.playingConsideringHoldSetting</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>48</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>sampler.turntable2.player2.playingConsideringHoldSetting</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>49</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>sampler.turntable2.player3.playingConsideringHoldSetting</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>50</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>sampler.turntable2.player4.playingConsideringHoldSetting</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>51</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>sampler.turntable2.player5.playingConsideringHoldSetting</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>52</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>sampler.turntable2.player6.playingConsideringHoldSetting</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>53</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>application.toggleShowEffects</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>17</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.slicer8Slice1</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>32</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.slicer8Slice2</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>33</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.slicer8Slice3</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>34</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.slicer8Slice4</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>35</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.slicer8Slice5</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>36</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.slicer8Slice6</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>37</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.slicer8Slice7</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>38</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.slicer8Slice8</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>39</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.bounceLoop00625BeatInterval</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>16</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.bounceLoop0125BeatInterval</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>17</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.bounceLoop025BeatInterval</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>18</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.bounceLoop05BeatInterval</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>19</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.bounceLoop1BeatInterval</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>20</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.bounceLoop2BeatInterval</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>21</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.bounceLoop4BeatInterval</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>22</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.bounceLoop8BeatInterval</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>23</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.cueOrJumpIfAlreadySet1</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>0</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.cueOrJumpIfAlreadySet2</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>1</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.cueOrJumpIfAlreadySet3</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>2</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.cueOrJumpIfAlreadySet4</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>3</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.cueOrJumpIfAlreadySet5</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>4</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.cueOrJumpIfAlreadySet6</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>5</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.cueOrJumpIfAlreadySet7</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>6</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.cueOrJumpIfAlreadySet8</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>7</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.deckSlipToggle</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>1</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>4</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>turntable2</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>4</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>application.automix</string><key>midiChannel</key><integer>0</integer><key>midiData</key><integer>3</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.key</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>2</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2</string><key>midiChannel</key><integer>0</integer><key>midiData</key><integer>3</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>turntable1.key</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>2</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.clearCuePoint1</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>8</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.clearCuePoint2</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>9</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.clearCuePoint3</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>10</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.clearCuePoint4</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>11</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.clearCuePoint5</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>12</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.clearCuePoint6</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>13</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.clearCuePoint7</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>14</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable1.clearCuePoint8</string><key>midiChannel</key><integer>6</integer><key>midiData</key><integer>15</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.clearCuePoint1</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>8</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.clearCuePoint2</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>9</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.clearCuePoint3</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>10</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.clearCuePoint4</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>11</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.clearCuePoint5</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>12</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.clearCuePoint6</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>13</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.clearCuePoint7</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>14</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>keyPath</key><string>turntable2.clearCuePoint8</string><key>midiChannel</key><integer>7</integer><key>midiData</key><integer>15</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict/></dict><dict><key>controlType</key><string>rotary</string><key>keyPath</key><string>turntable2.scratchingMove</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>12</integer><key>midiMessageType</key><integer>3</integer><key>rotaryAcceleration</key><integer>100</integer></dict><dict><key>keyPath</key><string>application.toggleShowTools</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>15</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>controlType</key><string>rotary</string><key>keyPath</key><string>turntable1.scratchingMove</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>12</integer><key>midiMessageType</key><integer>3</integer><key>rotaryAcceleration</key><integer>100</integer></dict><dict><key>keyPath</key><string>turntable1.fx3ParameterValue</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>13</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>turntable1</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>37</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>turntable1.fx1SelectRotary</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>45</integer><key>midiMessageType</key><integer>3</integer></dict><dict><key>keyPath</key><string>turntable1</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>39</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>turntable1.autoLoop4BeatInterval</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>11</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>turntable2.autoLoop4BeatInterval</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>11</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>musicLibrary.toggleLibrarySource</string><key>midiChannel</key><integer>3</integer><key>midiData</key><integer>0</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>buttonMode</key><string>toggle</string><key>keyPath</key><string>application.toggleShowTools</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>15</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>musicLibrary</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>16</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>turntable1.gotoBeginning</string><key>midiChannel</key><integer>4</integer><key>midiData</key><integer>6</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>turntable2.gotoBeginning</string><key>midiChannel</key><integer>5</integer><key>midiData</key><integer>6</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>turntable1.key</string><key>midiChannel</key><integer>4</integer><key>midiData</key><integer>5</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>turntable2.key</string><key>midiChannel</key><integer>5</integer><key>midiData</key><integer>5</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>turntable1.fx3Enabled</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>41</integer><key>midiMessageType</key><integer>1</integer><key>output</key><dict><key>midiChannel</key><integer>0</integer></dict><key>rotarySensitivity</key><real>84</real></dict><dict><key>keyPath</key><string>turntable1</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>43</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>sampler.toggleSamplerShown</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>18</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>sampler</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>16</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>sampler.toggleSamplerShown</string><key>midiChannel</key><integer>2</integer><key>midiData</key><integer>18</integer><key>midiMessageType</key><integer>1</integer></dict><dict><key>keyPath</key><string>sampler</string><key>midiChannel</key><integer>1</integer><key>midiData</key><integer>32</integer><key>midiMessageType</key><integer>3</integer></dict></array><key>editor</key><string>djay Pro-5.0.3</string><key>endpointName</key><string>DJControl Inpulse 200 Mk2</string><key>schemeVersion</key><integer>1</integer><key>version</key><integer>0</integer></dict></plist>
Hope this helps others.
This topic was modified 2 years ago 6 times by beyondthetech
