Mk2 mapping, works for djay Pro AI 5
I wasn’t aware there was an Mk2 version of the Inpulse 200, so I didn’t understand why the mapping file provided here ( https://support.hercules.com/en/product/djcontrolinpulse200-en/) wasn’t showing up in the djay app when I imported it.
I modified the USB ID in the file to match the ID found in my Mac’s System Report (116961584, had to combine and convert the Vendor and Product ID to decimal), then it imported and matched my device successfully.
Since the Mk2 doesn’t have a mid-EQ dial, I removed the duplicate mapping then re-added the high-EQ.
Save the below code as DJControl Inpulse 200 Mk2.djayMidiMapping
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>USBID</key>
<integer>116961584</integer>
<key>controls</key>
<array>
<dict>
<key>keyPath</key>
<string>turntable1.playPause</string>
<key>midiChannel</key>
<integer>1</integer>
<key>midiData</key>
<integer>7</integer>
<key>midiMessageType</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.playPause</string>
<integer>2</integer>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.cuePositionOrJumpConsideringPlayState1</string>
<key>midiData</key>
<integer>6</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.cuePositionOrJumpConsideringPlayState1</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.bpmSync</string>
<key>midiData</key>
<integer>5</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.bpmSync</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.loopIn</string>
<key>midiData</key>
<integer>9</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.loopOutAndReloopOrUnloop</string>
<key>midiData</key>
<integer>10</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.loopIn</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.loopOutAndReloopOrUnloop</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.speed</string>
<key>midiData</key>
<integer>8</integer>
<integer>3</integer>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.speed</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.scratchingMode</string>
<key>midiData</key>
</dict>
<dict>
<key>controlType</key>
<string>rotary</string>
<key>keyPath</key>
<string>turntable1.scratchingMove</string>
<key>midiData</key>
<key>rotaryAcceleration</key>
<integer>100</integer>
<key>rotarySensitivity</key>
<real>30</real>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.scratchingMode</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.scratchingMove</string>
<key>midiData</key>
<real>30</real>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.jogPitchBendModeToggle</string>
<key>midiData</key>
<key>output</key>
<dict>
<key>flipped</key>
<true/>
</dict>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.jogPitchBendModeToggle</string>
<key>midiData</key>
<key>output</key>
<dict>
<key>flipped</key>
<true/>
</dict>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.pitchBendMove</string>
<key>midiData</key>
<real>30</real>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.pitchBendMove</string>
<key>midiData</key>
<real>30</real>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.jogSeekMove</string>
<integer>4</integer>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.jogSeekMove</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.fx1Enabled</string>
<key>midiData</key>
<integer>0</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.fx1ParameterValue</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.fx1WetDryValue</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.fx2Enabled</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.fx2ParameterValue</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.fx2WetDryValue</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>mixer.crossfade</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>mixer.lineVolume1</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>mixer.lineVolume2</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.filter</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.filter</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.lowEQ</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.highEQ</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.gain</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.gain</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.highEQ</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.lowEQ</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>mixer.monitorActive1</string>
<key>midiData</key>
<integer>12</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>mixer.monitorActive2</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>musicLibrary.toggleLibrarySource</string>
<key>midiData</key>
</dict>
<dict>
<key>flipped</key>
<true/>
<key>keyPath</key>
<string>musicLibrary.libraryRotary</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>musicLibrary.load1</string>
<key>midiData</key>
<integer>13</integer>
</dict>
<dict>
<key>keyPath</key>
<string>musicLibrary.load2</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.autoLoopDurationDouble</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.autoLoopDurationHalf</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.autoLoopDurationDouble</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.autoLoopDurationHalf</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.cueOrJumpIfAlreadySet1</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.cueOrJumpIfAlreadySet2</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.cueOrJumpIfAlreadySet3</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.cueOrJumpIfAlreadySet4</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.cueOrJumpIfAlreadySet5</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.cueOrJumpIfAlreadySet6</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.cueOrJumpIfAlreadySet7</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.cueOrJumpIfAlreadySet8</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.bounceLoop00625BeatInterval</string>
<key>midiData</key>
<integer>16</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.bounceLoop0125BeatInterval</string>
<key>midiData</key>
<integer>17</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.bounceLoop025BeatInterval</string>
<key>midiData</key>
<integer>18</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.bounceLoop05BeatInterval</string>
<key>midiData</key>
<integer>19</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.bounceLoop1BeatInterval</string>
<key>midiData</key>
<integer>20</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.bounceLoop2BeatInterval</string>
<key>midiData</key>
<integer>21</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.bounceLoop4BeatInterval</string>
<key>midiData</key>
<integer>22</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.bounceLoop8BeatInterval</string>
<key>midiData</key>
<integer>23</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>buttonMode</key>
<string>toggle</string>
<key>keyPath</key>
<string>application.toggleShowEffects</string>
<key>midiData</key>
<key>output</key>
<dict>
<key>flipped</key>
<true/>
</dict>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.slicer8Slice1</string>
<key>midiData</key>
<integer>32</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.slicer8Slice2</string>
<key>midiData</key>
<integer>33</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.slicer8Slice3</string>
<key>midiData</key>
<integer>34</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.slicer8Slice4</string>
<key>midiData</key>
<integer>35</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.slicer8Slice5</string>
<key>midiData</key>
<integer>36</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.slicer8Slice6</string>
<key>midiData</key>
<integer>37</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.slicer8Slice7</string>
<key>midiData</key>
<integer>38</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.slicer8Slice8</string>
<key>midiData</key>
<integer>39</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>sampler.turntable1.player1.playingConsideringHoldSetting</string>
<key>midiData</key>
<integer>48</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>sampler.turntable1.player2.playingConsideringHoldSetting</string>
<key>midiData</key>
<integer>49</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>sampler.turntable1.player3.playingConsideringHoldSetting</string>
<key>midiData</key>
<integer>50</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>sampler.turntable1.player4.playingConsideringHoldSetting</string>
<key>midiData</key>
<integer>51</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>sampler.turntable1.player5.playingConsideringHoldSetting</string>
<key>midiData</key>
<integer>52</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>sampler.turntable1.player6.playingConsideringHoldSetting</string>
<key>midiData</key>
<integer>53</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>sampler.turntable2.player1.playingConsideringHoldSetting</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>sampler.turntable2.player2.playingConsideringHoldSetting</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>sampler.turntable2.player3.playingConsideringHoldSetting</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>sampler.turntable2.player4.playingConsideringHoldSetting</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>sampler.turntable2.player5.playingConsideringHoldSetting</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>sampler.turntable2.player6.playingConsideringHoldSetting</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.slicer8Slice1</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.slicer8Slice2</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.slicer8Slice3</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.slicer8Slice4</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.slicer8Slice5</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.slicer8Slice6</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.slicer8Slice7</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.slicer8Slice8</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.bounceLoop00625BeatInterval</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.bounceLoop0125BeatInterval</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.bounceLoop025BeatInterval</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.bounceLoop05BeatInterval</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.bounceLoop1BeatInterval</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.bounceLoop2BeatInterval</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.bounceLoop4BeatInterval</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.bounceLoop8BeatInterval</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.cueOrJumpIfAlreadySet1</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.cueOrJumpIfAlreadySet2</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.cueOrJumpIfAlreadySet3</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.cueOrJumpIfAlreadySet4</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.cueOrJumpIfAlreadySet5</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.cueOrJumpIfAlreadySet6</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.cueOrJumpIfAlreadySet7</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.cueOrJumpIfAlreadySet8</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.deckSlipToggle</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>application.automix</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.key</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.key</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.clearCuePoint1</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.clearCuePoint2</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.clearCuePoint3</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.clearCuePoint4</string>
<key>midiData</key>
<integer>11</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.clearCuePoint5</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.clearCuePoint6</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.clearCuePoint7</string>
<key>midiData</key>
<integer>14</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.clearCuePoint8</string>
<key>midiData</key>
<integer>15</integer>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.clearCuePoint1</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.clearCuePoint2</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.clearCuePoint3</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.clearCuePoint4</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.clearCuePoint5</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.clearCuePoint6</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.clearCuePoint7</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.clearCuePoint8</string>
<key>midiData</key>
<key>output</key>
<dict/>
</dict>
<dict>
<key>keyPath</key>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>application.toggleShowTools</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.fx3ParameterValue</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.fx1SelectRotary</string>
<key>midiData</key>
<integer>45</integer>
</dict>
<dict>
<key>keyPath</key>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.autoLoop4BeatInterval</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.autoLoop4BeatInterval</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>musicLibrary</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.gotoBeginning</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable2.gotoBeginning</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>turntable1.fx3Enabled</string>
<key>midiData</key>
<integer>41</integer>
<key>output</key>
<dict>
</dict>
<real>84</real>
</dict>
<dict>
<key>keyPath</key>
<key>midiData</key>
<integer>43</integer>
</dict>
<dict>
<key>keyPath</key>
<string>sampler.toggleSamplerShown</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<string>sampler</string>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<key>midiData</key>
</dict>
<dict>
<key>keyPath</key>
<key>midiData</key>
</dict>
</array>
<key>editor</key>
<string>djay Pro-5.0.3</string>
<key>endpointName</key>
<string>DJControl Inpulse 200 Mk2</string>
<key>schemeVersion</key>
<key>version</key>
</dict>
</plist>
Hope this helps others.
This topic was modified 3 years ago 6 times by beyondthetech
