MacBook Air M2 Problem
Hi Guys,
I unsucessfully tried to install my Inpulse 300 Controller to my MacBook Air.
Any ideas...?
The details:
Apple MacBook Air 2023 / M2 / Ventura 13.7.1
Used Hercules Driver: DJSeriesInstall_6_51s
Problem: Instant crash after restart. Freezes in DJUCED & Serato Light after 30-40 Minutes.
Error Message:
The error message indicates that the DJC Inpulse 300 Control Panel app crashed on your Mac due to a "segmentation fault," which is a memory access error.
The crash (seems to be) caused by an invalid memory access at a specific address (0x00000000dbdb0000), meaning the app tried to access a part of memory it shouldn’t have. This often points to an issue with the app itself or an incompatibility with the operating system or hardware.
Full crash log:
Translated Report (Full Report Below)
Process:               DJCInpulse300ControlPanel [902]
Path:                  /Applications/DJHERCULESMIX/*/DJCInpulse300ControlPanel.app/Contents/MacOS/DJCInpulse300ControlPanel
Identifier:            com.hercules.DJCInpulse300ControlPanel
Version:               1.1.3 (1.1.3)
Code Type:             ARM-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2024-11-11 08:06:00.3649 +0100
OS Version:            macOS 13.7.1 (22H221)
Report Version:        12
Anonymous UUID:        2A67BE08-205F-1E2C-1F67-092AB95E22DF
Time Awake Since Boot: 82 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x00000000dbdb0000
Exception Codes:       0x0000000000000001, 0x00000000dbdb0000
Termination Reason:    Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process:   exc handler [902]
VM Region Info: 0xdbdb0000 is not in any region.  Bytes before following region: 647266304
      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
      UNUSED SPACE AT START
      __TEXT                      1026f8000-10270c000    [   80K] r-x/r-x SM=COW  ...0ControlPanel
Kernel Triage:
VM - (arg = 0x0) pmap_enter retried due to resource shortage
Thread 0 Crashed::  Dispatch queue: com.apple.main-thread
0   libsystem_platform.dylib             0x1a8d3fe64 _platform_strlen + 4
1   libsystem_trace.dylib                0x1a8a93814 _os_log_impl_flatten_and_send + 1944
2   libsystem_trace.dylib                0x1a8a96474 _os_log_with_args_impl + 404
3   libsystem_asl.dylib                  0x1ad9e1914 _vsyslog + 264
4   libsystem_asl.dylib                  0x1ad9d29bc syslog + 44
5   hdjsapi                              0x1027d11bc HDJS_GetServerVersion + 212
6   DJCInpulse300ControlPanel            0x10270177c 0x1026f8000 + 38780
7   DJCInpulse300ControlPanel            0x1026fc174 0x1026f8000 + 16756
8   DJCInpulse300ControlPanel            0x1026fd30c 0x1026f8000 + 21260
9   Foundation                           0x1a9d88014 __NSFireDelayedPerform + 372
10  CoreFoundation                       0x1a8e0c2e8 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 32
11  CoreFoundation                       0x1a8e0bf90 __CFRunLoopDoTimer + 940
12  CoreFoundation                       0x1a8e0bae8 __CFRunLoopDoTimers + 356
13  CoreFoundation                       0x1a8df1268 __CFRunLoopRun + 1852
14  CoreFoundation                       0x1a8df03d8 CFRunLoopRunSpecific + 612
15  HIToolbox                            0x1b2649df0 RunCurrentEventLoopInMode + 292
16  HIToolbox                            0x1b2649c2c ReceiveNextEventCommon + 648
17  HIToolbox                            0x1b2649984 _BlockUntilNextEventMatchingListInModeWithFilter + 76
18  AppKit                               0x1ac01a38c _DPSNextEvent + 636
19  AppKit                               0x1ac019528 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 716
20  AppKit                               0x1ac00d98c -[NSApplication run] + 464
21  AppKit                               0x1abfe4ddc NSApplicationMain + 880
22  dyld                                 0x1a89bbfd8 start + 2412
Thread 1:
0   libsystem_pthread.dylib              0x1a8d0ed8c start_wqthread + 0
Thread 2:
Thread 3:
Thread 4:
Thread 5:: com.apple.NSEventThread
0   libsystem_kernel.dylib               0x1a8cd3ef4 mach_msg2_trap + 8
1   libsystem_kernel.dylib               0x1a8ce6220 mach_msg2_internal + 80
2   libsystem_kernel.dylib               0x1a8cdcb58 mach_msg_overwrite + 604
3   libsystem_kernel.dylib               0x1a8cd4270 mach_msg + 24
4   CoreFoundation                       0x1a8df2704 __CFRunLoopServiceMachPort + 160
5   CoreFoundation                       0x1a8df0fe4 __CFRunLoopRun + 1208
6   CoreFoundation                       0x1a8df03d8 CFRunLoopRunSpecific + 612
7   AppKit                               0x1ac144a18 _NSEventThread + 172
8   libsystem_pthread.dylib              0x1a8d13fa8 _pthread_start + 148
9   libsystem_pthread.dylib              0x1a8d0eda0 thread_start + 8
Thread 0 crashed with ARM Thread State (64-bit):
    x0: 0x00000000dbdb0000   x1: 0x00000000dbdb0000   x2: 0x0000000000000000   x3: 0x000000016d704288
    x4: 0x000000016d704bf6   x5: 0x0000000000000016   x6: 0x0000000000000000   x7: 0x0000000000000000
    x8: 0x0000000000007fff   x9: 0x0000000000000020  x10: 0x0000000000000400  x11: 0x0000000000000001
   x12: 0x0000000000000000  x13: 0x0000000000000006  x14: 0x0000000000000006  x15: 0x000000027e518000
   x16: 0x00000001a8d3fe60  x17: 0x000000020698b1f8  x18: 0x0000000000000000  x19: 0x00000000000003f8
   x20: 0x0000000000000000  x21: 0x0000000000000000  x22: 0x000000016d704282  x23: 0x000000016d704bfa
   x24: 0x0000000000000001  x25: 0x00000000000003f8  x26: 0x0000000000000000  x27: 0x000000016d704bf8
   x28: 0x00000000dbdb0000   fp: 0x000000016d704b70   lr: 0x00000001a8a93814
    sp: 0x000000016d703880   pc: 0x00000001a8d3fe64 cpsr: 0x40001000
   far: 0x00000000dbdb0000  esr: 0x92000006 (Data Abort) byte read Translation fault
Binary Images:
       0x1026f8000 -        0x10270bfff com.hercules.DJCInpulse300ControlPanel (1.1.3) <f04d92af-cc66-3779-b0c8-a7ed9d92511c> /Applications/DJHERCULESMIX/*/DJCInpulse300ControlPanel.app/Contents/MacOS/DJCInpulse300ControlPanel
       0x1027c4000 -        0x1027dffff com.hercules.hdjsapi (1.0) <36439fe0-3ba3-320d-924d-1295da92ea73> /Library/Frameworks/hdjsapi.framework/Versions/A/hdjsapi
       0x109d68000 -        0x109d73fff libobjc-trampolines.dylib (*) <4daa2f71-4c51-3179-9c85-34a3e49c7fc0> /usr/lib/libobjc-trampolines.dylib
       0x1a8d3f000 -        0x1a8d45ffb libsystem_platform.dylib (*) <26b1286a-70dc-3e34-99d0-73d26257de71> /usr/lib/system/libsystem_platform.dylib
       0x1a8a8e000 -        0x1a8aa8fff libsystem_trace.dylib (*) <d023b5ec-98bf-3cb8-bbe0-7370f798e0b5> /usr/lib/system/libsystem_trace.dylib
       0x1ad9cc000 -        0x1ad9e3ffb libsystem_asl.dylib (*) <43158526-d04b-33c1-9dcf-7cbaa16aa677> /usr/lib/system/libsystem_asl.dylib
       0x1a9d0e000 -        0x1aa6d3fff com.apple.Foundation (6.9) <85439347-8d4e-3c37-a41a-ae79b0bffd8b> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
       0x1a8d73000 -        0x1a924cfff com.apple.CoreFoundation (6.9) <4a35b66a-3b0e-34fd-811d-c44fb389ce8f> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
       0x1b2619000 -        0x1b294cfff com.apple.HIToolbox (2.1.1) <c8970896-b9d1-3fd0-aa1e-99bc8ff4e84d> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
       0x1abfe1000 -        0x1acef1fff com.apple.AppKit (6.9) <1a4ffce3-6623-3c15-9d96-dcb94ea59e23> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
       0x1a89b6000 -        0x1a8a44d13 dyld (*) <668a9a3c-85c0-3a58-8691-565e6db4c3ca> /usr/lib/dyld
       0x1a8d0d000 -        0x1a8d19fff libsystem_pthread.dylib (*) <e74e3db0-f8cb-34ab-831e-db30cbec154f> /usr/lib/system/libsystem_pthread.dylib
       0x1a8cd3000 -        0x1a8d0cff7 libsystem_kernel.dylib (*) <5738cf33-a520-3e9e-86f4-ff53217708a6> /usr/lib/system/libsystem_kernel.dylib
               0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)
Writable regions: Total=292.7M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=292.7M(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               128K        1
Activity Tracing                   256K        1
CG backing stores                 5056K        4
ColorSync                          512K       24
CoreGraphics                        32K        2
CoreServices                       176K        1
Dispatch continuations            64.0M        1
Foundation                          16K        1
Kernel Alloc Once                   32K        1
MALLOC                            92.3M       35
MALLOC guard page                  192K       10
MALLOC_MEDIUM (reserved)         120.0M        1         reserved VM address space (unallocated)
STACK GUARD                       56.1M        6
Stack                             10.6M        6
VM_ALLOCATE                        112K        7
__AUTH                             695K      177
__AUTH_CONST                      13.7M      334
__CTF                               824        1
__DATA                            3145K      320
__DATA_CONST                      15.9M      338
__DATA_DIRTY                       791K      115
__FONT_DATA                        2352        1
__LINKEDIT                       803.5M        4
__OBJC_RO                         66.4M        1
__OBJC_RW                         2012K        1
__TEXT                           253.3M      352
dyld private memory                272K        2
mapped file                      188.7M       41
shared memory                      928K       17
TOTAL                              1.7G     1805
TOTAL, minus reserved VM space     1.5G     1805
Full Report
{"app_name":"DJCInpulse300ControlPanel","timestamp":"2024-11-11 08:06:00.00 +0100","app_version":"1.1.3","slice_uuid":"f04d92af-cc66-3779-b0c8-a7ed9d92511c","build_version":"1.1.3","platform":1,"bundleID":"com.hercules.DJCInpulse300ControlPanel","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 13.7.1 (22H221)","roots_installed":0,"name":"DJCInpulse300ControlPanel","incident_id":"C86829A8-7C87-48A4-9F07-21EAD71B9207"}
  "uptime" : 82,
  "procRole" : "Foreground",
  "version" : 2,
  "userID" : 501,
  "deployVersion" : 210,
  "modelCode" : "Mac14,15",
  "coalitionID" : 910,
  "osVersion" : {
    "train" : "macOS 13.7.1",
    "build" : "22H221",
    "releaseType" : "User"
  "captureTime" : "2024-11-11 08:06:00.3649 +0100",
  "incident" : "C86829A8-7C87-48A4-9F07-21EAD71B9207",
  "pid" : 902,
  "translated" : false,
  "cpuType" : "ARM-64",
  "roots_installed" : 0,
  "bug_type" : "309",
  "procLaunch" : "2024-11-11 08:05:59.9176 +0100",
  "procStartAbsTime" : 1958203799,
  "procExitAbsTime" : 1968683307,
  "procName" : "DJCInpulse300ControlPanel",
  "procPath" : "\/Applications\/DJHERCULESMIX\/*\/DJCInpulse300ControlPanel.app\/Contents\/MacOS\/DJCInpulse300ControlPanel",
  "bundleInfo" : {"CFBundleShortVersionString":"1.1.3","CFBundleVersion":"1.1.3","CFBundleIdentifier":"com.hercules.DJCInpulse300ControlPanel"},
  "storeInfo" : {"deviceIdentifierForVendor":"0B757896-C368-5D3B-914C-3E12C66243A7","thirdParty":true},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "com.hercules.DJCInpulse300ControlPanel",
  "crashReporterKey" : "2A67BE08-205F-1E2C-1F67-092AB95E22DF",
  "codeSigningID" : "com.hercules.DJCInpulse300ControlPanel",
  "codeSigningTeamID" : "5UJ4BQ4F4B",
  "codeSigningFlags" : 570503953,
  "codeSigningValidationCategory" : 6,
  "codeSigningTrustLevel" : 0,
  "sip" : "enabled",
  "vmRegionInfo" : "0xdbdb0000 is not in any region.  Bytes before following region: 647266304\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      __TEXT                      1026f8000-10270c000    [   80K] r-x\/r-x SM=COW  ...0ControlPanel",
  "exception" : {"codes":"0x0000000000000001, 0x00000000dbdb0000","rawCodes":[1,3688562688],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x00000000dbdb0000"},
  "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":902},
  "ktriageinfo" : "VM - (arg = 0x0) pmap_enter retried due to resource shortage\n",
  "vmregioninfo" : "0xdbdb0000 is not in any region.  Bytes before following region: 647266304\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      __TEXT                      1026f8000-10270c000    [   80K] r-x\/r-x SM=COW  ...0ControlPanel",
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 0,
  "threads" : [{"triggered":true,"id":7906,"threadState":{"x":[{"value":3688562688},{"value":3688562688},{"value":0},{"value":6131040904},{"value":6131043318},{"value":22},{"value":0},{"value":0},{"value":32767},{"value":32},{"value":1024},{"value":1},{"value":0},{"value":6},{"value":6},{"value":10709204992},{"value":7127432800,"symbolLocation":0,"symbol":"_platform_strlen"},{"value":8700604920},{"value":0},{"value":1016},{"value":0},{"value":0},{"value":6131040898},{"value":6131043322},{"value":1},{"value":1016},{"value":0},{"value":6131043320},{"value":3688562688}],"flavor":"ARM_THREAD_STATE64","lr":{"value":7124629524},"cpsr":{"value":1073745920},"fp":{"value":6131043184},"sp":{"value":6131038336},"esr":{"value":2449473542,"description":"(Data Abort) byte read Translation fault"},"pc":{"value":7127432804,"matchesCrashFrame":1},"far":{"value":3688562688}},"queue":"com.apple.main-thread","frames":[{"imageOffset":3684,"symbol":"_platform_strlen","symbolLocation":4,"imageIndex":3},{"imageOffset":22548,"symbol":"_os_log_impl_flatten_and_send","symbolLocation":1944,"imageIndex":4},{"imageOffset":33908,"symbol":"_os_log_with_args_impl","symbolLocation":404,"imageIndex":4},{"imageOffset":88340,"symbol":"_vsyslog","symbolLocation":264,"imageIndex":5},{"imageOffset":27068,"symbol":"syslog","symbolLocation":44,"imageIndex":5},{"imageOffset":53692,"symbol":"HDJS_GetServerVersion","symbolLocation":212,"imageIndex":1},{"imageOffset":38780,"imageIndex":0},{"imageOffset":16756,"imageIndex":0},{"imageOffset":21260,"imageIndex":0},{"imageOffset":499732,"symbol":"__NSFireDelayedPerform","symbolLocation":372,"imageIndex":6},{"imageOffset":627432,"symbol":"__CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__","symbolLocation":32,"imageIndex":7},{"imageOffset":626576,"symbol":"__CFRunLoopDoTimer","symbolLocation":940,"imageIndex":7},{"imageOffset":625384,"symbol":"__CFRunLoopDoTimers","symbolLocation":356,"imageIndex":7},{"imageOffset":516712,"symbol":"__CFRunLoopRun","symbolLocation":1852,"imageIndex":7},{"imageOffset":512984,"symbol":"CFRunLoopRunSpecific","symbolLocation":612,"imageIndex":7},{"imageOffset":200176,"symbol":"RunCurrentEventLoopInMode","symbolLocation":292,"imageIndex":8},{"imageOffset":199724,"symbol":"ReceiveNextEventCommon","symbolLocation":648,"imageIndex":8},{"imageOffset":199044,"symbol":"_BlockUntilNextEventMatchingListInModeWithFilter","symbolLocation":76,"imageIndex":8},{"imageOffset":234380,"symbol":"_DPSNextEvent","symbolLocation":636,"imageIndex":9},{"imageOffset":230696,"symbol":"-[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":716,"imageIndex":9},{"imageOffset":182668,"symbol":"-[NSApplication run]","symbolLocation":464,"imageIndex":9},{"imageOffset":15836,"symbol":"NSApplicationMain","symbolLocation":880,"imageIndex":9},{"imageOffset":24536,"symbol":"start","symbolLocation":2412,"imageIndex":10}]},{"id":7909,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":11}]},{"id":7910,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":11}]},{"id":7929,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":11}]},{"id":7933,"frames":[{"imageOffset":7564,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":11}]},{"id":7939,"name":"com.apple.NSEventThread","frames":[{"imageOffset":3828,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":12},{"imageOffset":78368,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":12},{"imageOffset":39768,"symbol":"mach_msg_overwrite","symbolLocation":604,"imageIndex":12},{"imageOffset":4720,"symbol":"mach_msg","symbolLocation":24,"imageIndex":12},{"imageOffset":521988,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":7},{"imageOffset":516068,"symbol":"__CFRunLoopRun","symbolLocation":1208,"imageIndex":7},{"imageOffset":512984,"symbol":"CFRunLoopRunSpecific","symbolLocation":612,"imageIndex":7},{"imageOffset":1456664,"symbol":"_NSEventThread","symbolLocation":172,"imageIndex":9},{"imageOffset":28584,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":11},{"imageOffset":7584,"symbol":"thread_start","symbolLocation":8,"imageIndex":11}]}],
  "usedImages" : [
    "source" : "P",
    "arch" : "arm64",
    "base" : 4335828992,
    "CFBundleShortVersionString" : "1.1.3",
    "CFBundleIdentifier" : "com.hercules.DJCInpulse300ControlPanel",
    "size" : 81920,
    "uuid" : "f04d92af-cc66-3779-b0c8-a7ed9d92511c",
    "path" : "\/Applications\/DJHERCULESMIX\/*\/DJCInpulse300ControlPanel.app\/Contents\/MacOS\/DJCInpulse300ControlPanel",
    "name" : "DJCInpulse300ControlPanel",
    "CFBundleVersion" : "1.1.3"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4336664576,
    "CFBundleShortVersionString" : "1.0",
    "CFBundleIdentifier" : "com.hercules.hdjsapi",
    "size" : 114688,
    "uuid" : "36439fe0-3ba3-320d-924d-1295da92ea73",
    "path" : "\/Library\/Frameworks\/hdjsapi.framework\/Versions\/A\/hdjsapi",
    "name" : "hdjsapi",
    "CFBundleVersion" : "1.0"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 4460019712,
    "size" : 49152,
    "uuid" : "4daa2f71-4c51-3179-9c85-34a3e49c7fc0",
    "path" : "\/usr\/lib\/libobjc-trampolines.dylib",
    "name" : "libobjc-trampolines.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7127429120,
    "size" : 28668,
    "uuid" : "26b1286a-70dc-3e34-99d0-73d26257de71",
    "path" : "\/usr\/lib\/system\/libsystem_platform.dylib",
    "name" : "libsystem_platform.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7124606976,
    "size" : 110592,
    "uuid" : "d023b5ec-98bf-3cb8-bbe0-7370f798e0b5",
    "path" : "\/usr\/lib\/system\/libsystem_trace.dylib",
    "name" : "libsystem_trace.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7207698432,
    "size" : 98300,
    "uuid" : "43158526-d04b-33c1-9dcf-7cbaa16aa677",
    "path" : "\/usr\/lib\/system\/libsystem_asl.dylib",
    "name" : "libsystem_asl.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7144005632,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.Foundation",
    "size" : 10248192,
    "uuid" : "85439347-8d4e-3c37-a41a-ae79b0bffd8b",
    "path" : "\/System\/Library\/Frameworks\/Foundation.framework\/Versions\/C\/Foundation",
    "name" : "Foundation",
    "CFBundleVersion" : "1979.104.901"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7127642112,
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 5087232,
    "uuid" : "4a35b66a-3b0e-34fd-811d-c44fb389ce8f",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7287705600,
    "CFBundleShortVersionString" : "2.1.1",
    "CFBundleIdentifier" : "com.apple.HIToolbox",
    "size" : 3358720,
    "uuid" : "c8970896-b9d1-3fd0-aa1e-99bc8ff4e84d",
    "path" : "\/System\/Library\/Frameworks\/Carbon.framework\/Versions\/A\/Frameworks\/HIToolbox.framework\/Versions\/A\/HIToolbox",
    "name" : "HIToolbox"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7180521472,
    "CFBundleIdentifier" : "com.apple.AppKit",
    "size" : 15798272,
    "uuid" : "1a4ffce3-6623-3c15-9d96-dcb94ea59e23",
    "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
    "name" : "AppKit",
    "CFBundleVersion" : "2299.77.138"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7123722240,
    "size" : 584980,
    "uuid" : "668a9a3c-85c0-3a58-8691-565e6db4c3ca",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7127224320,
    "size" : 53248,
    "uuid" : "e74e3db0-f8cb-34ab-831e-db30cbec154f",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7126986752,
    "size" : 237560,
    "uuid" : "5738cf33-a520-3e9e-86f4-ff53217708a6",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "uuid" : "00000000-0000-0000-0000-000000000000"
  "sharedCache" : {
  "base" : 7123058688,
  "size" : 3586146304,
  "uuid" : "c23c8eaf-0e55-380f-8553-41916c29d775"
  "vmSummary" : "ReadOnly portion of Libraries: Total=1.0G resident=0K(0%) swapped_out_or_unallocated=1.0G(100%)\nWritable regions: Total=292.7M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=292.7M(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nAccelerate framework               128K        1 \nActivity Tracing                   256K        1 \nCG backing stores                 5056K        4 \nColorSync                          512K       24 \nCoreGraphics                        32K        2 \nCoreServices                       176K        1 \nDispatch continuations            64.0M        1 \nFoundation                          16K        1 \nKernel Alloc Once                   32K        1 \nMALLOC                            92.3M       35 \nMALLOC guard page                  192K       10 \nMALLOC_MEDIUM (reserved)         120.0M        1         reserved VM address space (unallocated)\nSTACK GUARD                       56.1M        6 \nStack                             10.6M        6 \nVM_ALLOCATE                        112K        7 \n__AUTH                             695K      177 \n__AUTH_CONST                      13.7M      334 \n__CTF                               824        1 \n__DATA                            3145K      320 \n__DATA_CONST                      15.9M      338 \n__DATA_DIRTY                       791K      115 \n__FONT_DATA                        2352        1 \n__LINKEDIT                       803.5M        4 \n__OBJC_RO                         66.4M        1 \n__OBJC_RW                         2012K        1 \n__TEXT                           253.3M      352 \ndyld private memory                272K        2 \nmapped file                      188.7M       41 \nshared memory                      928K       17 \n===========                     =======  ======= \nTOTAL                              1.7G     1805 \nTOTAL, minus reserved VM space     1.5G     1805 \n",
  "legacyInfo" : {
  "threadTriggered" : {
    "queue" : "com.apple.main-thread"
  "logWritingSignature" : "a1b0915d11c41272a733381ac59917999410d11c",
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "5ffde50ce2aacd000d47a95f",
      "factorPackIds" : {
      "deploymentId" : 240000448
      "rolloutId" : "60186475825c62000ccf5450",
      "factorPackIds" : {
      "deploymentId" : 240000083
  "experiments" : [
      "treatmentId" : "3dff9c91-a8fb-424e-a656-c8d6e6037574",
      "experimentId" : "662152ede2d11d1408c4db33",
      "deploymentId" : 400000014
      "treatmentId" : "45f4e2a5-551b-4bc2-a2dc-19c244dda8f8",
      "experimentId" : "6643969b3099cf28e049862f",
      "deploymentId" : 400000007
Model: Mac14,15, BootROM 11881.41.5, proc 8:4:4 processors, 8 GB, SMC
Graphics: Apple M2, Apple M2, Built-In
Display: Color LCD, spdisplays_2880x1864Retina, Main, MirrorOff, Online
Memory Module: LPDDR5, Hynix
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4387), wl0: May 27 2023 01:34:59 version 20.96.31.0.8.7.148 FWID 01-126f2c4c
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
USB Device: DJControl Inpulse 300
Thunderbolt Bus: MacBook Air, Apple Inc.
This topic was modified 3 weeks ago by DeeZett
Hello Deezett,
Welcome to the Hercules users forum.
1) As Hercules DJ Control Panel app is not absolutely needed to use DJControl Inpulse 300 in macOS (it is used for diagnostic and firmware update), you can uninstall the DJ Control Panel app (delete the folder DJHERCULESMIX in \Applications folder), restart the computer and let us know if you still get this crash in Djuced and Serato.
(I am not sure the control panel app crash is the cause of DJ software crash, it may be a symptom of another issue).
2) To know more on your computer configuration
a) USB connection of the DJ controller
Please precise what is the connection between the DJ controller and the USB-C port on you MacBook:
i) if you use a USB-C to USB-A adapter, please precise the brand and model of this adapter.
If it is a no-name adapter, I suggest trying with another one (as Apple USB-C to USB or Startech or Belkin) as some very cheap non-name USB-C adapter are OK for low power USB connection (as USB keys) but not stable enough for USB devices needing a full USB bus power (as audio interfaces or webcams).
ii) if you use a USB hub, make sure the USB hub is powered by a power adapter.
b) Conflict with another USB device
If another USB device is connected to the MacBook at the same time, please try if removing it changes or not the occurrence of the software crash.
c) USB port
try connecting the DJ controller to the other USB port of the MacBook.
d) Drivers
Please confirm if your install DJSeriesInstall_6_51s as a fresh install (with no previous Hercules DJ control panel installed) or you had another version as 6.44s installed before.
e) Djuced & Serato error reports.
i) Please precise the version of
ii) When Djuced and Serato freeze, do they display an error message when you close and restart them?
iii) When you restart Djuced, do you see an bugsplat screen?
