Hi, so I just bought Hercules Inpulse 500. I’m using the newest Serato DJ Pro and I have problem with led showing which deck is playing. The first deck is working fine but second deck is not. Crossfader is on middle position and both track are playing.
The on-air deck vumeter checks the deck is playing + crossfader position + volume fader: what is the position of deck 2 volume fader?
Volume is set on max too. The problem is only in Serato. When I check it in Djuced everything was fine.
Hello MasterCook89,
You have found a bug!
Indeed, deck 2 on-air no longer lights up on deck 2 since Serato DJ 4.0.0 (Lite & Pro), with DJC Inpulse 500 and T7, in macOS as in Windows.
The latest Serato DJ release with deck 2 on-air backlight is 3.3.5.
So I inform Hercules to have it fixed.
Oh,m! I’m glad it’s just a bug. Thanks for help.
Hi UX team!
I am encountering the same problem. Is there any solution in the near future?
Greetings Peter
Salut,
The on-air LED bug has been corrected, it is no longer in Serato DJ Lite and Pro 4.0.7 with DJControl Inpulse 500.
What is you version of Serato DJ?
I do not use the latest version, so I know no that I need to update. Thank you for letting me know!
