DJUCED PRO slow downs
3 Users
I own a ASUS TUF A16 FX608JMR which is a powerful laptop,
When I launch DJUCED PRO with Windows 11, it slow downs while 30 seconds, if I launch a track, it lags.
After 30 seconds everything is normal,
What could it be ?
Thank you very much!
Were these tracks previously analyzed and part of you library?
If these are new tracks, then DJUCED need to analyze them first, which requires some ressources and would explain the lag you are experiencing.
The Phat One
@ckiceluila Which version of Windows 11 are you using? Start, Run, type Winver, press Enter, and let me know what it says.
@Baumi
26H1 is not the cause of all the problems under Win 11, which again, most people won't use until the mainstream release.
The Phat One
In order to give him the right tip, I first need the information @DJ. I have a lot of information about Windows, but I don't want to go into it here.
