Jogwheels a bit hard
Hello I'm a new owner of the great T7 controller,
I use DJUCED Pro, when the motor is running, I think that the jog wheels are a bit hard to scratch or to do back spins.
I did the jog calibration procedure without any changes.
Is it normal behavior ?
Thank you
Hello Ckiceluila,
Happy New Year.
1) To scratch, make sure the vinyl discs lay on the convex side (vinyl discs slightly bend so that one side is concave while the other is convex): if you try scratching on the concave side, it is a bit hard to scratch.
 2) To improve the back spin, you may need adding backspin washers, the impact is very strong:
- if you have access to a 3D printer, in a fab lab or a 3D print store, you may download the 3D files on https://www.printables.com/model/1036238-djcontrol-inpulse-t7-backspin-washers
- if you have no access to a 3D printer, you can order it on Hercules shop https://shop.hercules.com/en_eu/backspin-washer-kit.html
Big thank you for yours advises Team UX
I purchased backspin washers and now it so much better, yeah !!!
