29/01/2026 2:53 pm
Historically I had working a MIDI mapping allowing me to use the SHIFT+Outer Jog wheel for library scroll and SHIFT+PLAY to load track. The code was as follows, but this no longer works on more recent DJ Pro versions. Is this still possible and if so what changes do I need to make?
<midi app=" 3.2.1.914">
<control channel="2" event_type="Note On" control="5">
<userio event="click">
<load_track deck_set="Default" deck_id="0" slot_id="0">
<translation action_on="press" behaviour="explicit"/>
</load_track>
</userio>
<userio event="output">
<load_track_feedback deck_set="Default" deck_id="0" slot_id="0">
<translation action_on="any">
<alias name="off" value="0"/>
<alias name="on" value="127"/>
</translation>
</load_track_feedback>
</userio>
</control>
<control channel="6" event_type="Control Change" data_type="Relative 2's Complement" control="9">
<midi_library_scroll deck_set="Default" deck_id="0" slot_id="0">
<translation action_on="any" behaviour="explicit"/>
</midi_library_scroll>
</userio>
</control>
<control channel="5" event_type="Control Change" data_type="Relative 2's Complement" control="9">
</userio>
</control>
<control channel="3" event_type="Note On" control="5">
<load_track deck_set="Default" deck_id="1" slot_id="0">
</load_track>
</userio>
<load_track_feedback deck_set="Default" deck_id="1" slot_id="0">
</translation>
</userio>
</control>
</midi>
18/02/2026 9:40 pm
SHIFT + PLAY → Track Laden <load_track deck_set="Default" deck_id="0" slot_id="0">
That would be an example of what chattgpt suggests. I did not write that note.
MFG Baumi Maybe it will help you find a bug that will make it work again.
