27/04/2025 3:36 am
Im having problem connecting DJ Control Mix on their windows app, i installed the driver but cannot be connected
28/04/2025 3:43 pm
How are you connecting the controller to your computer: using a cable or through Bluetooth ?
Under Windows, your device needs to be physically connected using a USB cable to the PC for DJAY to correctly see and use your device.
A Bluetooth connection can only be used for iOS, Android and MacOS.
The Phat One
28/04/2025 4:03 pm
Hello Rnzzzl,
What do you call "their Windows app"?
If you mean djay app, DJControl Mix works in djay Pro free version when you connect the USB cable to the PC with Windows 11.
Enclosed is a screenshot in
- djay 5.3.28150
- Windows 11 version 24H2, build 26100.3476.
=> DJControl Mix is detected and works, with no message, it works directly.
