Hercules 200 MK2 + ...
Hercules 200 MK2 + Qobuz, looking for compatible DJUCED, 6.0.4
Hi all,
my friend bought Hercules 200 MK2 controler, and wants to use Qobuz. she uses a mac.
200 MK2 requires Djuced 6 to be recognized, and since 6.0.5 Qobuz is not supported.
I'm looking for 6.0.4 version, but I can't find it, even in Djuced's archives.
can you help me ?
Thank you 🙂
Hello FBRC,
Sorry for that, but the agreement between Qobuz and Djuced is no longer valid so Djuced can no longer play Qobuz streamings.
Thanks for answering, I know that Qobuz is no longer supported on new versions of Djuced. That is why I am kindly asking for an older version. Can you please help me ? My friend now owns a contrôler she cannot use ! Thank you
Hello FBRC,
To play streaming from Qobuz in Djuced, 2 services are needed
1) Djuced incorporating the code to play Qobuz streaming,
2) Qobuz playing streaming through the ports that Djuced opens.
I do not know if Qobuz can still work in old Djuced versions, but did you try with Djuced 5.3.8?
Hello, we tried Djuced 40°. Qobuz was recognized, which was annonced like being compatible again with Djuced, and it is.
Problem is that 200 MK2 controler works only with Djuced 6.0 and above.
That's why I need a version between 6.0 and 6.0.5. Hoping Qobuz would work correctly...
Thank's for your help 🙂
(sorry for my bad english...)
I can see on archive's page that 5.3.8 can work with 200MK2 but only Windows installer can be downloaded !
