AUTO HOT CUES
Hello, I have a problem with the auto hot cues they don't go where they should. Sometimes there are 3beats later, sometimes they are 2 beats earlier. How can i fix that ?
This topic was modified 10 months ago by UNKEY
Hello Unkey,
1) Do you use DJUCED Pro or is it another app as Mixed In Key, Rekordbox...?
2) Auto hot cue may never be perfect, they are only proposals.
Anyway, if you can contact me in the private messaging area (I will send you the same message in the private area so that you see where it is) and send me an example of a track audio file where the auto hot cue is not good, I can transfer it to DJUCED team so that they look at it and check what should be done.
