Hercules DJControl ...
Hercules DJControl Inpulse 200
The Inpulse 200 primarily outputs audio through its RCA outputs. To capture this audio for streaming, you'll need to route it into your computer.
Option 1: External Audio Interface: Connect the RCA outputs to an external audio interface that connects to your computer via USB. This will allow you to capture the audio directly.
Option 2: Virtual Audio Cable: If your DJ software supports it, you can use virtual audio routing software to send the audio output directly to Discord.
