10/09/2025 5:29 am
You may expect help if you describe your technical problem.
Tech forums help if you follow forum rules, so you should explain
- your issue with technical words,
- your computer settings as in the posting rules,
otherwise you seem unable to read a tech answer, perform tech operations and report results.
Tech forums are bad if you throw a tantrum as in the double post: tech forums need only tech posts. If a post looks messy, no one think tou will read any answers, so no one will answer.
