Connect both sound output and headphones to laptop on a Hercules DJ Control mp3 e2
Hello there,
Hope you are doing well ?
I am facing an issue that I can't solve even if I tried many manipulations in the settings.
I am currently training on a Hercules DJ control mp3 e2 and at home, I am connecting both of my speakers and headphones on the computer.
As the DJ Control Mp3 e2 as no headphones output, I have to do this.
The speakers are connected to the AUX connection and the headphones to an external USB - AUX adapter.
Is there any way to configure:
- Master sound => Internal Headphones
- Headphones => USD AUX output
Attached image shows what I tried
Thanks a lot in advance !
Djuced lets you address only 1 audio device, so if you want to use 2 audio devices, you need to
1) aggregate the different audio devices in 1 virtual audio device as ASIO4ALL, and set them with the same sample rate (44 or 48 khz)
2) then select the virtual audio device as playback device in your DJ software,
3) and then assign the master to 1 stereo out and the preview to another stereo out.
Remark: it will always be a complicated as virtual audio devices are complicated, it is much easier to use a 4-channel sound card like this
https://www.amazon.com/Optimal-Shop-External-Channel-Surround/dp/B00Q4WQ7XW/?th=1
