DJUCED Stem control for Universal DJ
I wanted to try DJUCED Stems with my Universal DJ controller, but there is no button for it because it is of course a very old controller model.
There was an old post where a user requested a custom slicer mode mapping file for this controller, and you proposed a mapping that would replace one of the modes CUE, FX, Sample, Loop.
If you created a mapping file for slicer support, would that be configurable in DJUCED to use the slicer mode as stem mode with this controller?
Provided that it is possible, I would really appreciate if you could make this mapping file, replacing the Sample mode with the Slicer.
Thanks
Topic Tags
Hello.
As you said the Universal DJ is an old controller and it doesn't "respect" some MIDI logics that newer controllers have (Inpulse range).
For what I tested, It seems that you can replace the Sampler mode with the STEMS mode from DJUCED Settings.
I can see that there's a LED bug feedback with the Universal DJ with STEMS mode, I'll report to DJUCED Team, but you can still use Pad 1/4 to controls the stems.
