Problem with FXs.. ...
[Closed] Problem with FXs.. [FIXED] (sort of..)
Situation : All FXs are passing by the Deck #2.
OS : Windows 11
System : Desktop i5-12th gen., 16 gigs RAM, more than needed space available on the HD, only used for music stuff.
Controller : Inpulse 300 MK2
Last major change : upgraded to Windows 11 at 7:40 this morning
Was working before : OF THE COURSE!!!
Scenarios:
  1. Deck #1 is playing, turn on FXs, open the knob : nothing
  2. Deck #1 is playing, FX off or on on deck #1, turn on FXs on deck #2, open the knob of deck 2 : BINGO!
  3. Deck #1 and Deck #2 are playing, turn on and open FX on deck #2 : effects on BOTH DECKS
  4. Set FXs on deck #1 to channel 2 & 4 (like deck #2), repeat scenario #1 : nothing.
#4 is weird.. The FX knobs seems completely deactivated.
I updated the controller's drivers and I reinstalled DJUCED over the actual install (I htink it just refreshed it). I checked the settings and nothing seems to be changed.. I'M a bit lost here..
**UPDATE**
Downgrading to Windows 10 DID NOT fix the problem...
**FIXED**
It seems the HERCULES DRIVERS are not ready for a Windows 11 upgrade and DJUCED can't handle it.
Drivers aren't also good for a downgrade once you realized the mistake..
Uninstalling/Reinstalling drivers are making things worst.
Solution : redo my computer from skratch with Windows 10 and never touch it again.
14 hours, not a single reply from the support team.. good job guys!
This topic was modified 2 years ago 3 times by Yannick
This discussion was moved to
https://community.hercules.com/community/djcontrol-inpulse-300/fx-not-working-after-windows-11-upgrade/
Please read the forum rules ( https://community.hercules.com/forum-rules/ ):
"before starting a new discussion, check if you can find an open discussion on the same subject, and if you can find such an open discussion, it is better to write a new post in that discussion than to start a new discussion".
So the current discussion is closed.
