Using filter and FX...
Using filter and FX separately on Inpulse 500 with Serato DJ Pro
Hi all, I have an Inpulse 500 console, and my biggest problem in Serato DJ Pro was that when I activate the FX pads, I lose control on the Filter. So, after studying and thinking, I found a workaround.
I remapped the console, and use the two AUX knobs on the left. The AUX Filter now controls the amount of FX on the left deck, the AUX Vol. controls the amount of FX on the right deck. The two Filter knobs are now controlling only the Filter.
Also, I remapped the Sampler pads to control the Stems section.
If you think that it will help you, I'm attaching the XML file, which you must copy in the C:\Users\(computer name)\Music\_Serato_\MIDI\Xml
Let me know if that works for you.
(PS. I see that I cannot attach the .xml file, so I will copy and paste it here.)
<midi app="Serato DJ Pro 3.1.1.1251">
<control channel="7" event_type="Note On" control="19">
<userio event="click">
<auto_loop_roll_specific_length deck_set="Default" deck_id="0" slot_id="5">
<translation action_on="any" behaviour="explicit"/>
</auto_loop_roll_specific_length>
</userio>
<userio event="output">
<auto_loop_specific_length deck_set="Default" deck_id="0" slot_id="5">
<translation action_on="any">
<alias name="selected" value="0"/>
<alias name="on" value="127"/>
<alias name="off" value="0"/>
</translation>
</auto_loop_specific_length>
</translation>
</translation>
</translation>
</translation>
</translation>
</translation>
</userio>
</control>
<control channel="7" event_type="Note On" control="18">
<auto_loop_roll_specific_length deck_set="Default" deck_id="0" slot_id="4">
</userio>
<auto_loop_specific_length deck_set="Default" deck_id="0" slot_id="4">
</translation>
</translation>
</translation>
</translation>
</translation>
</translation>
</translation>
</userio>
</control>
<control channel="7" event_type="Note On" control="35">
<case>
<condition>
<effect_bank_mode deck_set="DJ Effects" deck_id="0" slot_id="0" operator="equal" cmp_value="Single Mode"/>
<touch_effect_modifier deck_set="DJ Effects" deck_id="0" slot_id="0" operator="equal" cmp_value="on"/>
</condition>
<effect_slot_enable deck_set="DJ Effects" deck_id="0" slot_id="0">
<translation action_on="press" behaviour="static" static_value="on"/>
</effect_slot_enable>
</userio>
</translation>
</translation>
</translation>
</translation>
</userio>
</case>
<case>
<condition>
<touch_effect_modifier deck_set="DJ Effects" deck_id="0" slot_id="1" operator="equal" cmp_value="on"/>
<effect_bank_mode deck_set="DJ Effects" deck_id="0" slot_id="0" operator="equal" cmp_value="Multi Mode"/>
</condition>
<effect_level_1_slot_enable deck_set="DJ Effects" deck_id="0" slot_id="1">
</effect_level_1_slot_enable>
</userio>
</translation>
</translation>
</translation>
</translation>
</userio>
</case>
<case>
<condition>
<touch_effect_modifier deck_set="DJ Effects" deck_id="0" slot_id="1" operator="equal" cmp_value="off"/>
</condition>
<translation action_on="press" behaviour="toggle"/>
</userio>
</translation>
</translation>
</translation>
</translation>
</userio>
</case>
<case>
<condition>
<touch_effect_modifier deck_set="DJ Effects" deck_id="0" slot_id="0" operator="equal" cmp_value="off"/>
</condition>
</userio>
</translation>
</translation>
</translation>
</translation>
</userio>
</case>
</control>
<control channel="2" event_type="Control Change" data_type="Absolute 7" control="1">
<deck_filter_auto deck_set="Default" deck_id="0" slot_id="0">
</deck_filter_auto>
</userio>
</control>
<control channel="3" event_type="Control Change" data_type="Absolute 7" control="1">
<deck_filter_auto deck_set="Default" deck_id="1" slot_id="0">
</deck_filter_auto>
</userio>
</control>
<control channel="8" event_type="Note On" control="18">
<auto_loop_roll_specific_length deck_set="Default" deck_id="1" slot_id="4">
</userio>
<auto_loop_specific_length deck_set="Default" deck_id="1" slot_id="4">
</translation>
</translation>
</translation>
</translation>
</translation>
</translation>
</translation>
</userio>
</control>
<control channel="8" event_type="Note On" control="16">
<auto_loop_specific_length deck_set="Default" deck_id="1" slot_id="9">
</userio>
</translation>
</translation>
</translation>
</translation>
</userio>
</control>
<control channel="7" event_type="Note On" control="16">
<auto_loop_specific_length deck_set="Default" deck_id="0" slot_id="9">
</userio>
</translation>
</translation>
</translation>
</translation>
</userio>
</control>
<control channel="7" event_type="Note On" control="17">
<auto_loop_specific_length deck_set="Default" deck_id="0" slot_id="10">
</userio>
</translation>
</translation>
</translation>
</translation>
</userio>
</control>
<control channel="8" event_type="Note On" control="17">
<auto_loop_specific_length deck_set="Default" deck_id="1" slot_id="10">
</userio>
</translation>
</translation>
</translation>
</translation>
</userio>
</control>
<control channel="2" event_type="Note On" control="7">
<play deck_set="Default" deck_id="0" slot_id="0">
</play>
</userio>
</translation>
</play>
</translation>
</play>
</translation>
</play>
</translation>
</play>
</translation>
</play>
</translation>
</play>
</translation>
</play>
</userio>
</control>
<control channel="8" event_type="Note On" control="19">
<auto_loop_roll_specific_length deck_set="Default" deck_id="1" slot_id="5">
</userio>
<auto_loop_specific_length deck_set="Default" deck_id="1" slot_id="5">
</translation>
</translation>
</translation>
</translation>
</translation>
</translation>
</translation>
</userio>
</control>
<control channel="8" event_type="Note On" control="35">
<case>
<condition>
<touch_effect_modifier deck_set="DJ Effects" deck_id="1" slot_id="0" operator="equal" cmp_value="on"/>
<effect_bank_mode deck_set="DJ Effects" deck_id="1" slot_id="0" operator="equal" cmp_value="Single Mode"/>
</condition>
<effect_slot_enable deck_set="DJ Effects" deck_id="1" slot_id="0">
</userio>
</translation>
</translation>
</translation>
</translation>
</userio>
</case>
<case>
<condition>
<effect_bank_mode deck_set="DJ Effects" deck_id="1" slot_id="0" operator="equal" cmp_value="Multi Mode"/>
<touch_effect_modifier deck_set="DJ Effects" deck_id="1" slot_id="1" operator="equal" cmp_value="on"/>
</condition>
<effect_level_1_slot_enable deck_set="DJ Effects" deck_id="1" slot_id="1">
</userio>
</translation>
</translation>
</translation>
</translation>
</userio>
</case>
<case>
<condition>
<touch_effect_modifier deck_set="DJ Effects" deck_id="1" slot_id="1" operator="equal" cmp_value="off"/>
</condition>
</userio>
</translation>
</translation>
</translation>
</translation>
</userio>
</case>
<case>
<condition>
<touch_effect_modifier deck_set="DJ Effects" deck_id="1" slot_id="0" operator="equal" cmp_value="off"/>
</condition>
</userio>
</translation>
</translation>
</translation>
</translation>
</userio>
</case>
</control>
<control channel="1" event_type="Control Change" data_type="Absolute 7" control="10">
<case>
<condition>
</condition>
<effect_level_1_slot_parameter_1 deck_set="DJ Effects" deck_id="0" slot_id="1">
</effect_level_1_slot_parameter_1>
</userio>
</case>
<case>
<condition>
</condition>
<effect_slot_parameter_2 deck_set="DJ Effects" deck_id="0" slot_id="0">
</effect_slot_parameter_2>
</userio>
</case>
<case>
<condition>
</condition>
<effect_slot_parameter_1 deck_set="DJ Effects" deck_id="0" slot_id="0">
</effect_slot_parameter_1>
</userio>
</case>
<case>
<condition>
</condition>
<effect_level_1_slot_parameter_1 deck_set="DJ Effects" deck_id="0" slot_id="3">
</userio>
</case>
<case>
<condition>
</condition>
<effect_level_1_slot_parameter_1 deck_set="DJ Effects" deck_id="0" slot_id="2">
</userio>
</case>
<case>
<condition>
</condition>
<effect_slot_parameter_3 deck_set="DJ Effects" deck_id="0" slot_id="0">
</effect_slot_parameter_3>
</userio>
</case>
</control>
<control channel="1" event_type="Control Change" control="9">
<case>
<condition>
</condition>
<effect_slot_parameter_1 deck_set="DJ Effects" deck_id="1" slot_id="0">
</userio>
</case>
<case>
<condition>
</condition>
<effect_level_1_slot_parameter_1 deck_set="DJ Effects" deck_id="1" slot_id="1">
</userio>
</case>
<case>
<condition>
</condition>
<effect_level_1_slot_parameter_1 deck_set="DJ Effects" deck_id="1" slot_id="2">
</userio>
</case>
<case>
<condition>
</condition>
<effect_slot_parameter_2 deck_set="DJ Effects" deck_id="1" slot_id="0">
</userio>
</case>
<case>
<condition>
</condition>
<effect_slot_parameter_3 deck_set="DJ Effects" deck_id="1" slot_id="0">
</userio>
</case>
<case>
<condition>
</condition>
<effect_level_1_slot_parameter_1 deck_set="DJ Effects" deck_id="1" slot_id="3">
</userio>
</case>
</control>
</midi>
This topic was modified 2 years ago 2 times by catalin66ro
