22/10/2025 10:27 am
I try the new feature assing audiosources. So i assined my mic to an enpty slot. It apears, and the VU is pegging while im speaking, but i cant here anithing. Wheter on my weadphones (directly pluged to hercules) nor over the Line-Out. What are im doing wrong?
25/10/2025 12:56 am
I have the latest version and the update worked without any problems for me. Could it be that you had a Windows update yesterday to build win 11/27975.1? That it changed in win 11?
26/10/2025 10:11 am
yes, im always up to date with the windows updates. But how would it affect my problem?
26/10/2025 6:44 pm
I know of several cases where this has caused problems for others. Check the folder where the settings are located, uninstall the software, restart your computer, and reinstall it.
