Hercules Stream 200...
Hercules Stream 200 XLR Blackscreen
Since i updated to the newest version
Software - 2.0.3 [01.44]
Firmware - 1.88
The Stream 200 XLR keeps getting a blackscreen here and then.
Sometimes it works for an hour sometimes it only takes a few seconds after i plugged it out and in again.
In blackscreen i can hear and talk, but i can´t change anything and the software says there is no device found.
It also makes some programms crash.
Before i updated i haven´t had any problems just when i restartet my PC it sometimes had the same problem.
I am using
Windows 10 Home
10.0.19045 Build 19045
Please help.
This topic was modified 1 year ago by Slamsas
Hi Slamsas,
Do you still have this issue ?
