Is there a way to u...
Is there a way to use a Headset?
How can I use a Byerdynamics headset MMX 330 Pro. And I mean both, headphone and mic. It comes with a combined 3.5mm TRRS or a seperate 3.5 TRS each for mic and headphone. Is there a way?
If you use a headset with a 3.5 mm jack, yes, but the quality isn't very good. I would recommend a dynamic microphone or an XLR microphone if you want good quality. According to Amazon, the Byerdynamics MMX 330 Pro has a 3.5 mm jack, so technically yes.
