Sound level reset a...
Sound level reset at each reboot
The problem is new, it is like this since I've reinstalled Windows 11.
Every time I restart my machine, the sound levels on the 200XLR reset to 100%. It looks like the levels are not saved...
Is there any work-around?
Does it concern all volumes ( Creator and Audience) ?
Did you try to reset to factory settings?
Can you gives us full Software version  2.XX[XX] a,d Firmware version: XX
Thx
