15/01/2016 12:23 am
hiya everyone,
would really appreciate it if i can get some advice please.
ive only owned a hercules dj control instinct for 4 days, worked great through my new speakers and new head phones.
now its only working through my apple mac speakers. this is twice that its happened, the first time i took the decks back and swapped for a different one (same model) i would like to note that all connections are correct, i will probably give up and spend more money on some proper ones to start off with if there isnt anything that i can do. if anyone has had the same problem or can recommend anything id be grateful,
