4-mx not working on...
4-mx not working on mac osx 10.6.6 help
hello, my 4-mx was working perfectly with 10.6.5 but when i updated to 10.6.6 is not working anymore.
i wrote an email to the technical support but didnt get an answer for almost a month now.
updated to the 4-mx newest driver v2.47 but still no good.
wondering if they are working on a new driver to fix this issue soon?
running vdj pro 7.0.3
thanks
djsin
hello,
4-mx is fully working in mac os 10.6.6 32-bit with virtualdj.
please precise what doesnt work on your computer, for example
- controller not detected in hercules control panel
- controller not detected in virtualdj
- audio not working in virtualdj: please precise
- controls not working: please precise
as virtualdj pro 7.0.3 pro was not available 1 month ago (it was a beta version: a beta version has bugs, it is what makes the difference with a release version), with which version did you meet the issues on 4-mx 1 month ago: virtualdj 7.0.2 pro or virtualdj 7.0.2 le 4-mx?
4-Mx is fully working in Mac OS 10.6.6 32-bit with VirtualDJ.
Please precise what doesn't work on your computer, for example
- controller not detected in Hercules control panel
- controller not detected in VirtualDJ
- audio not working in VirtualDJ: please precise
As VirtualDJ Pro 7.0.3 Pro was not available 1 month ago (it was a beta version: a beta version has bugs, it is what makes the difference with a release version), with which version did you meet the issues on 4-Mx 1 month ago: VirtualDJ 7.0.2 Pro or VirtualDJ 7.0.2 LE 4-Mx?
