1
Posts
2
Users
Reactions
Views
29/12/2013 9:38 pm
its really kinda important that the adjustment be smooth for a good smooth transition..but it jumps abruptly when adjusting while the track is playing. my mp3 e2 didnt have this issue. would there be a fix for that?
30/12/2013 3:25 am
Please check the behavior of your EQ controls as described in the following procedure:
http://ts.hercules.com/faqs/eng/her_eng_00435.pdf
If the transition is not smooth (meaning that it seems to jump over values instead of going from 0 to 127), then there might be a hardware problem with your unit that would require a replacement.
