control air or cont...
control air or control instinct
hi, im a beginner dj and i want to get a controller. where i live hercules control air costs 130€ and hercules control instinct costs 90€. which should i get?
i dont think the contacless sensor that has control air is worth its price, but maybe it has more things than instinct does. i dont know which one should i buy. what do you recommend?
The major differences you should consider are the size and the fact that the DJ AIR has pads (instead of buttons for the Instinct), which can be an added bonus if you are thinking of making your own beats and using them live.
Otherwise, the two are more or less the same.
You should take the Hercules AIR, because you can control the FX parameters and you have better Pads
