deep bass frequenci...
deep bass frequencies missing (vdj 7 w/ hercules mk4)
dear all, i have a small problem with my hercules mk 4 using vdj 7.
the software and the controller work perfectly. however, wether im playing on an average sound system or using the built-in recording feature of vdj, some deep bass frequencies seem to be missing. the bass isnt just as pumping and full-power as it is when i play the songs i use in vlc oder windows media player.
other listeners of my sets have verified this set to me - i can give you an example too: https://soundcloud.com/doktor-faustus/dr-faustus-004 .
do you hear it too (i think it is quite clear to hear if you use good headphones or speaker - amongst others, i have been using a quite decent home cinema soundsystem and akg k18le and the problem and there has always been this problem)
i have tried reinstalling the software.
1) Have you tried disabling the Auto Gain (in VDJ > Config > Options) ?
2) Have you tried with VDJ 8 Pro?
